[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by Alianato View Postbuild from Vorke Z6 Plus stock and based on Magendanz ATV stock version
https://uptobox.com/z83pl10xye4o
No hangs, restart, freeze.
LCD work fine
Videos smooth.
Try it
Thanks again
Originally posted by Alianato View Postyou may want to try the following rom
it's based on the following rom by tillaz87 all credit should go to him, I only adapted to the Tanix TX9 Pro / Vorke Z6 Plus
http://freaktab.com/forum/tv-player-...ndard-ultimate
download from:
unzip with 7zip
it's working fine for me, it's an ATV rom
Originally posted by Deki View Post
Hiiiii i have try this rom ! is very very very good and very very fast !!! just one problem screen on tanix alway writt : "boot" even when the box is off (power off) any solution for solve this ?
I recognize the problem with the led showing "boot" but I am not sure it can be solved, except perhaps with a black tape on top of the led
try the following rom if you like, it's based on tillaz87 ATV rom but it's a new version with improvements and it allows to be converted to non ATV
I still had no time to try it
rom
convert to non ATV (install via TWRP)
This auto wipes data, flash in recovery.
If you want the status bar edit build.prop Code:
persist.sys.useTvStatusBar=true
to Code:
persist.sys.useTvStatusBar=false
Note: this patch was made for original rom so it's not sure it will work on the adapted one, anyway there is a good chance it might workLast edited by Alianato; 01 March 2018, 23:21.
Originally posted by Deki View PostLol black tape is not the solution :-) i dont understand why box show « boot » when is powered off ?
For me no problem if box dont show time... just when power off screen turn off
or second solution is cut cable screen but after dont view when box is ON :-/
the original firmware was made for a non led box so I am afraid any change could break the code, perhaps the problem does not occur with the latest rom I just posted
Originally posted by Alianato View Posttry the following rom if you like, it's based on tillaz87 ATV rom but it's a new version with improvements and it allows to be converted to non ATV
rom
to Code:
this rom is very very good this is the only problem encountered really damage
new version of the tool to convert to non ATV (install via TWRP)
https://mega.nz/#!1dJUBZ5T!68ObvcsHm...TKo9KZsKiJyFFE
most probably it will not solve the LED screen issue
There are currently 1483 users online. 2 members and 1481 guests.
