[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by shqual View PostLow resolution back after every reboot. Any suggestions?)
Originally posted by promosign View Post
I would like to have more info on the subject
update: don't worry, I already knowgoogle translator is my friend
there is also a suggestion that the following will fix the low resolution problem after boot
in build.prop change the following
# sys.display-size.check = false
or
sys.display-size.check = true
I still had no time to try it but it's worth a shotLast edited by Alianato; 16 February 2018, 22:10.
How do I load this patch?
Work on z6 plus I guess, right?
Originally posted by Luca View Post
Thank you guys
the same I cannot say about the changes in the build.prop
the patch for the LCD is installed in the same way as the OTA, via TWRP, I did it for the Tanix TX9 Pro but should work the same with the Vorke Z6 Plus
There are currently 2959 users online. 1 members and 2958 guests.
