[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
    Originally posted by Deki View Post
    Ok i have found wher imput script :-) your script work good. Just for me i need to change resolution to 720p because in 1080p i have sound problem
    When i put :
    echo 1 > /sys/class/graphics/fb0/blank
    echo 720p50hz > /sys/class/display/mode
    echo 1 > /sys/class/graphics/fb0/freescale_mode
    echo 0 0 1919 1079 > /sys/class/graphics/fb0/free_scale_axis
    echo 0 0 1919 1079 > /sys/class/graphics/fb0/window_axis
    echo 0 0 -1 -1 > /sys/class/video/axis
    echo 0x10001 > /sys/class/graphics/fb0/free_scale
    echo 0 > /sys/class/graphics/fb0/blank
    echo "1280 720 1280 720" > /sys/class/graphics/fb1/scale_axis
    screen bug. Where is my error ?
    try the following
    echo 0 0 1279 719 > /sys/class/graphics/fb0/free_scale_axis
    echo 40 30 1239 689 > /sys/class/graphics/fb0/window_axis
    echo 1 > /sys/class/graphics/fb1/blank
    or possibly
    echo 0 > /sys/class/ppmgr/ppscaler
    echo 0 > /sys/class/graphics/fb0/free_scale
    then tell me
      Alianato Hi, I do not have problems of resolution at boot but I'm afraid that installing the patch LCD via OTA will create problems boot resolution 480p . What do you think?
      Ciao
        Ciao
        I have problem without patch :-) so i think problem is TV to use with box because i dont have resolution problem with my second tv
          Originally posted by Alianato View Post
          try the following
          or possibly
          then tell me
          I have try all, dont work screen bug :-( grrr
            there is not much documentation about changing the resolution via script, today I was trying several variations of the script without success, there are several tools in the store that promise to automatically change the resolution, I try several of them without success, for instance "Easy DPI Changer" is one of them, but it didn't work for me...
            you can try yourself, I suppose the settings for 720p should be 1280x720@50hz with DPI = 142
            here is another post in this forum about same subject:
              http://freaktab.com/forum/main-categ...mlogic-devices
              thank you for help, but i have try a lot of combinaison but not success i think i come back to original tanix rom soon or i wait custom rom of Promosign
              Originally posted by promosign View Post
              And whether it is necessary?
              I will edit the stock firmware. I'm remaking Stock Tanix TX9 Pro (2018)
              With an Aroma installer for everyone.
              There will be an easy version with optimization and when installing the required one under each program
              No new about your custom rom ?
                I understand you perfectly
                  you may want to try the following rom, the resolution problem is gone
                  this is based on stock rom, not Android TV, first boot takes a long time
                  use 7zip to decompress
                    hi , what rom are you talking?
                      the new one I just posted, it's similar to the ones I posted before but without the resolution problem
                      this particular one is based on stock (not nano) and also not ATV, because it's the one I normally use
                        perfect, always very kind, thanks
                            Good new you dont have android tv version ? for me ATV is better for use with remote.
                              I can do a ATV version, stock or nano?
                                hi, excuse my ignorance, what are the differences between these possible versions? it is still not completely clear
