[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
you may want to try the following rom
it's based on the following rom by tillaz87 all credit should go to him, I only adapted to the Tanix TX9 Pro / Vorke Z6 Plus
http://freaktab.com/forum/tv-player-...ndard-ultimate
download from:
unzip with 7zip
it's working fine for me, it's an ATV rom
download from:
unzip with 7zip
Originally posted by Luca View Post
This rom is not good for me.I don't like ATV version. I had blocks and little overall usability. Too bad because the videos are really fluid at very high resolutions.
CheersLast edited by Alianato; 28 February 2018, 00:25.
hi Alianato since I would not want to bother you anymore in the future would you post me the complete procedure of how to replace the 3 files in the ROMs to fit them in our boxes?
I also suspect that there may be some small difference between tanix and vorke files that you assemble
When and if you can ..
In almost all the ROMs I tried, it seems to me that the videos do not go to more than 720p. In the stock ROM vorke and android tv version I tried the video resolution is OK up 4k.
I read somewhere that tanix had a youtube limitation problem at 720p despite very similar hw and rom to the vorke
Originally posted by Luca View Posthi Alianato since I would not want to bother you anymore in the future would you post me the complete procedure of how to replace the 3 files in the ROMs to fit them in our boxes?
Originally posted by Luca View PostIn almost all the ROMs I tried, it seems to me that the videos do not go to more than 720p. In the stock ROM vorke and android tv version I tried the video resolution is OK up 4k.
if you tell me what you want I can make it for you before making the video, basically I need to know
1) based on stock Vorke Z6 Plus or Tanix TX9 Pro?
2) ATV or not ATV?
3) based on Magendanz Stock or Nano?
don't know, perhaps you are right, the process I use could also be applied using Vorke stock instead of Tanix
2) ATV or not ATV?
based on Magendanz Nano
There are currently 1470 users online. 2 members and 1468 guests.
