S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
I have been playing with this ROM for a few hours. So here is what I have found so far.
1) Difficult to control apps & UI with mouse as it seems the trigger areas for different apps don't always work when pressed or isn't accurate. Also mouse roller don't work with some Apps like ES text editor etc.
2) For some reason my internet connection via the Ethernet port is incredibly slow.
3) Factory resetting the firmware puts the box frozen in boot animation and don't reset the box.
4) I flashed this firmware into my Mini M8S II via Amlogic USB tools and selected (Force Erase All) inc bootloader to be erased however it seems it did not erase the Android 6 bootloader.
5) Android System WebView is very old and therefore watching videos in web browser in HD is not possible. Tried to put in a updated Android System WebView from Play Store however it crashes and wont work.Last edited by DrDroid; 10 November 2019, 15:02.
Tested on DIVERMAX SPEEDBOX LITE: s905x 1 and 8 GB (the original rom for this box is so unstable).
I replace the _aml_dtb.PARTITION with Customization tool, as previously recommended in this post for the 1 and 8 GB memory.
At first boot runs good, this box have a wiffi remote and no problems (i try with oters remotes boxes and these don't work), only the constant message of bluetooth is annoying, but after of firts reboot the frequency decreased.
I installed a new launcher and now the functionality improved more than with the factory rom.
Originally posted by MULDER View PostTested on DIVERMAX SPEEDBOX LITE: s905x 1 and 8 GB (the original rom for this box is so unstable).
Originally posted by sagert View Post
Bluetooth.apk can be removed by the /system/app/Bluetooth.apk path.
Tanks! Bluetoth repaired.
But, there is some hack to repair the constant disconnection of the wifi?
Specifications for DIVERMAX SPEEDBOX LITE: s905x wifi says IEEE 802.11 b / g / n 2.4GHz
Originally posted by fabinus View PostGood morningI have an MXQ PRO 4K tv box with android 6.0.1;tell me if you can upgrade to android 7?.
Your prefix with which processor?Here ,look or enter your prefix in the Google search.
https://4pda.ru/forum/index.php?showtopic=780574
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 1860 users online. 1 members and 1859 guests.
