S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by sagert View Post- some videos didn't work properly in kodi... the image freezed, the sound went on.
- wifi and bluetooth are broken
- some keys from my remote are no longer recognized like the most important one... shut down for example
Originally posted by ksenchy View Post
Thanks. I have tried it- some videos didn't work properly in kodi... the image freezed, the sound went on.
minixfreak : This one is made for TX5....
https://forum.atvxperience.com/viewt...p?p=7149#p7149
unpack with: daivietpda@2019
Maybe you could add wifi drivers and BT :-)
Tried on several generic S905x and they all boot up and OS runs!!
sagert according to this the build you mentioned has locked bootloader....
MECOOL KM8 Google Certified Android TV Box with Voice Remote - Amlogic S905X Android 8.0 2GB RAM + 16GB ROM VP9 HDR10 Dolby Audio Support Youtube 4K
I made Lineage android 9.0 and optimized it using the LSpeed program.
shared_text.txt
LSpeed is a very good optimization program.
Thanks! With wifi drivers?
mxqproject.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf mxqproject.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
You can also use the kernel from atvexperience android 8.0 firmware.There will be more option.It must be replaced in boot.img.
There are currently 1883 users online. 0 members and 1883 guests.
