S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
    Originally posted by caccolino View Post
    how to flash?? i don't have a twrp
    Here is the instruction
    Select Descedant3.1.1
      https://github.com/s1a1g1e1r1t/AOSP_...s905x/projects
      but work on all s905x device?? I have a nexbox a95x
      i try the atv 9 pie but unfortunately wifi not work
        This is necessary for the kernel to have wifi support.You need to make a kernel with the necessary wifi modules.It is very difficult.
          So, it is suitable for Mini M8S II S905x, 2/8GB, right? If I want to rollback to stock android 6 or 7, I can use Burning tool 2.1.6, can I?
          Thanks for answer in advance!
            MMh...replace kernel?
            Anyone tried this yet:
              You can come back.Then jou can flash android 6, 7 through the Usb Burning Tool .
                May be useful.
                  Thanks! I will try
                    Works on my S905, but no wifi drivers for ssv6051
                    My devices:
                    Okko SmartBox | S905Y2, Unlocked | ATV9 Slimbox ROM
                      Make a kernel with the correct wifi driver.There is no detailed instruction on the internet how to do this.You will need this for several years!!
                        hi
                        i loaded this rom successfully but my remote does not work.
                        I decompiled the device tree file and edited remote data but remote didn't work again.
                        here is data from dtd file:
                        Code:
                            rc@c8100580 {
                                compatible = "amlogic, aml_remote";
                                dev_name = "meson-remote";
                                reg = <0x0 0xc8100580 0x0 0x44 0x0 0xc8100480 0x0 0x20>;
                                status = "okay";
                                protocol = <0x1>;
                                interrupts = <0x0 0xc4 0x1>;
                                pinctrl-names = "default";
                                pinctrl-0 = <0x21>;
                                map = <0x22>;
                                max_frame_time = <0xc8>;
                            custom_maps {
                                mapnum = <0x3>;
                                map0 = <0x23>;
                                map1 = <0x24>;
                                map2 = <0x25>;
                                linux,phandle = <0x22>;
                                phandle = <0x22>;
                                map_0 {
                                    mapname = "amlogic-remote-1";
                                    customcode = <0x7f80>;
                                    release_delay = <0x50>;
                                    debug_enable = <0x1>;
                                    fn_key_scancode = <0x52>;
                                    fn_key_scancode_other = <0x5b>;
                                    cursor_left_scancode = <0x25>;
                                    cursor_right_scancode = <0x27>;
                                    cursor_up_scancode = <0x26>;
                                    cursor_down_scancode = <0x28>;
                                    cursor_ok_scancode = <0xd>;
                                    size = <0x1f>;
                                    keymap = <0x30000b 0x310002 0x320003 0x330004 0x340005 0x350006 0x360007 0x370008 0x380009 0x39000a 0x58001c 0x44000e 0x510074 0x4d0071 0x260067 0x28006c 0x250069 0x27006a 0x1b009e 0x49008b 0xd001c 0x4e0073 0x560072 0x530066 0x9018e 0x11018f 0x540190 0x4f0191 0xbd00a5 0xbb00a3 0x520088>;
                                    linux,phandle = <0x23>;
                                    phandle = <0x23>;
                                map_1 {
                                    mapname = "amlogic-remote-2";
                                    customcode = <0xfe01>;
                                    size = <0x35>;
                                    keymap = <0x10002 0x20003 0x30004 0x40005 0x50006 0x60007 0x70008 0x80009 0x9000a 0xa000b 0x1f01d2 0x15008b 0x16000f 0xc0192 0xd0193 0xe0073 0xf0072 0x110066 0x1c006a 0x1b0069 0x190067 0x1a006c 0x1d001c 0x170071 0x4900db 0x43009e 0x1201d5 0x1401d6 0x1801d7 0x590166 0x5a00a6 0x100074 0x4200a5 0x4400a3 0x1e00a8 0x4b00d0 0x5800a4 0x460082 0x400083 0x380046 0x5701d0 0x5b01d1 0x54018e 0x4c018f 0x4e0190 0x550191 0x5300ed 0x5200ee 0x3900d4 0x4100d5 0xb00d6 0xd8 0x1300d9>;
                                    linux,phandle = <0x24>;
                                    phandle = <0x24>;
                                map_2 {
                                    mapname = "amlogic-remote-3";
                                    customcode = <0xbd02>;
                                    size = <0x11>;
                                    keymap = <0xca0067 0xd2006c 0x990069 0xc1006a 0xce0061 0x450074 0xc50085 0x800071 0xd0000f 0xd6007d 0x950066 0xdd0068 0x8c006d 0x890083 0x9c0082 0x9a0078 0xcd0079>;
                                    linux,phandle = <0x25>;
                                    phandle = <0x25>;
                        I've edited this part:
                        rc@c8100580 {
                        status = "okay";
                        protocol = <0x1>;
                        pinctrl-0 = <0x21>;
                        map = <0x22>;
                        custom_maps {
                        mapnum = <0x3>;
                        map0 = <0x23>;
                        map1 = <0x24>;
                        map2 = <0x25>;
                        phandle = <0x22>;
                        map_0 {
                        customcode = <0xf708>;
                        size = <0x1f>;
                        phandle = <0x23>;
                        map_1 {
                        size = <0x35>;
                        phandle = <0x24>;
                        map_2 {
                        size = <0x11>;
                        phandle = <0x25>;
                        but i dont know why my remote does not work and what are keymaps above!?
                        any ideas??
                        my custom code is : f708
                          I learned how to make firmware using program Amlogic Tool v 6.0 .And another program.Now you can install my firmware using the program USB Burning Tool v 2.1.7.Here are 2 of my firmware that can be installed using the program USB Burning Tool v 2.1.7 for windows
                            Originally posted by amirdelta View Post
                            hi
                            Code:
                             rc@c8100580 {
                            status = "okay";
                            protocol = <0x1>;
                            pinctrl-0 = <0x21>;
                            map = <0x22>;
                            custom_maps {
                            mapnum = <0x3>;
                            map0 = <0x23>;
                            map1 = <0x24>;
                            map2 = <0x25>;
                            phandle = <0x22>;
                            map_0 {
                            size = <0x1f>;
                            phandle = <0x23>;
                            map_1 {
                            size = <0x35>;
                            phandle = <0x24>;
                            map_2 {
                            size = <0x11>;
                            phandle = <0x25>;
                            rc@c8100580 {
                            status = "okay";
                            protocol = <0x1>;
                            pinctrl-0 = <0x21>;
                            map = <0x22>;
                            custom_maps {
                            mapnum = <0x3>;
                            map0 = <0x23>;
                            map1 = <0x24>;
                            map2 = <0x25>;
                            phandle = <0x22>;
                            map_0 {
                            size = <0x1f>;
                            phandle = <0x23>;
                            map_1 {
                            size = <0x35>;
                            phandle = <0x24>;
                            map_2 {
                            size = <0x11>;
                            phandle = <0x25>;
                            any ideas??
                            You should ask Stane1983.
                              Can you be more detailed?
                                Another program that I use is Unpacker Kitchtn for Android .She is from the site 4pda.But it is written in Russian, maybe someone will translate it for you.Here is written about her but in russian.
                                You can download it here in the archive 3 programs, select it
