S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
I remembered if there is an ota update ,then it can be edited.Convert the system.new.dat.br and system.transfer.list files to system.new.dat and to system.img.Then edit system.img.And convert it back to system.new.dat.br .And replace this file in update.zip and flash it in the update&backup program.
Originally posted by sagert View Post
I forgot to do this kernel 4.9 with wifi support.
You can also use the kernel from atvexperience android 8.0 firmware.There will be more option.It must be replaced in boot.img.
Originally posted by soldiaz View Post
Feel sorry, I do not understand
I have tried it to my mxq pro 4k 1/8gb. Successfully flashed with usb burning tool. But when i turn it on, my tv has no respon. I got a black blank screen. My box turns blue light normally but detected no signal in my tv.
So, in my case. It does not work for me.
any solution? O ya, i cannot reset from the av button to access the recovery mode anymore.
get stressful..
thanks for advices.
Originally posted by suriphen View PostI have tried it to my mxq pro 4k 1/8gb. Successfully flashed with usb burning tool. But when i turn it on, my tv has no respon. I got a black blank screen. My box turns blue light normally but detected no signal in my tv.
get stressful..
thanks for advices.
Originally posted by soldiaz View PostWhich build?
Guess you are supposed to flash 1GB build for your device!!
new problem is, i cannot root it, and the other roms seem dead.
Anyone keep this rom? {ROM} PoisonATV V4.9 S905X
thanks.
You can connect the console to the computer using the UART adapter.And find the answer.
https://mxqproject.com/uart-for-amlo...ting-up-guide/
is it the same function like we connect male male port to pc?
Thanks in advances.
ok i see.. it is a new tool for me, haven't tried it yet.
Thanks in advances.
Originally posted by sagert View Postmade Descedant 3.1.1 android 9.It seems to me he is fast.
On XDA improve constantly .
There are currently 2152 users online. 0 members and 2152 guests.
