S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by sagert View Post
The Android 9 ATV release is best rom Ive seen around here. But since it does noot work with my RTL87328bs chip I did not try to take a look inside the rom.
To do so, you have to unpack on Linux since AML Tools 6.0 for Windows is unstable and you cant unpack to check structure / remote location / DTB hardcoded maybe etc...
Originally posted by canbonbon View Post
Hello Sagert/Soldiaz, I was able to install this on Nexbox A95X. Its blazingly fast. Almost everything works except the known issues. No wifi or bluetooth. I am using Ethernet so that is fine. However, I am not able to make any remote work on the box. I have plenty of IR remotes lying around so I tried them all but none of them works. Any suggestions? I am going to use a USB remote for now but I would ideally like to be able to make one of the remotes work. Any suggestions? Thanks for all your help.
How to fix wifi and bluetooth S905X chip wifi Rtl8732bs on ATV8???Last edited by xmannamviet; 24 June 2019, 15:35.
Originally posted by adzyp View PostHi all, can someone please clarify my options here for what the latest is that I can burn to my Mini M8S II?
ive read through the thread but it seems to go off on a tangent half way through and now I?m a bit confused what the latest version I should be trying is?
There are currently 2131 users online. 0 members and 2131 guests.
