S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by andcraig View PostHi all,
with the new bootloader bundled with this firmware i'm unable to flash firmware from sd card created with Burn Card Maker.
I've installed successfully latest twrp...
Can someone help me? I've a Mini M8s II...
You probably installed twrp 3.2.3 of Magedanz .But it is for android 7.I edited it and now it is for android 8.For android 8 twrp is here.
So do not confuse
Originally posted by marcelov2 View Post
I can not install on my z69 4k 2gb
There are android 8 and 7.
TWRP starts correctly if I push pin on the back of TV box.
No,I've installed TWRP found on your gitub. The problem seems to be the bootloader. if I try to update firmware (older version) with sdcard the update doesn't start.
Hi Everyone,
I have a H96 Amologic s905X 2/16gb. I am new to this world but also very curious about it. I would appreciate if you guys could share a guide to follow to install Oreo on my tv box. I believe most of the boxes are already rooted. What steps do I need to follow once I download the files and tools that Lewy shared with us on first page ? Does the .img file needs to be modified somehow ? can the firmware be flashed through SD cards ? sorry for asking so many questions, I just want to make sure everything goes smooth without making any error and brick the device. Thanks in advance to you all, especially to the developers which put lots of effort on what they do and achieve. Your responses will be much appreciated
If twrp starts ,then go into it.In it clean wipe cache ,dalwik, system,data .And install any image to choose from your android 8.1 .Android 9.0 while slows down a bit.
if I convert img to zip with amlogic tools it doesn't install (error 6 in twrp) so I'm trying with sd card an pin method
[QUOTE = andcraig; n763029]
Я хочу установить более старую версию (стабильную версию ATV).
если я конвертирую img в zip с помощью amlogic tools, то он не устанавливается (ошибка 6 в twrp), поэтому я пытаюсь использовать SD-карту методом pin [/ QUOTE]
CWM Status 6, этот код ошибки произошел, потому что файл Updater-scpript мог не может быть прочитано, поскольку оно не было создано в формате Unix, и ОС Android не смогла установить это обновление.
Решение ошибки Status 6: загрузите и установите программу на ПК NotePad ++, измените формат на Unix и повторно сохраните файл updater-scpript.
А что нельзя установить прошивку Lewy android 8.0 через usb burn tool?And for what burn card maker?So easy to get into a dead end.We must follow the instructions.Other ways i do not know.
If you want to return to the old version of ATV ,then this is only through usb burning tool.Last edited by sagert; 19 February 2019, 12:57.
There are currently 2319 users online. 2 members and 2317 guests.
