S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by sagert View Post
Originally posted by alcaide View PostCho
This rom includes root access with supersu, I think that's not the problem, the recovery has disappeared I do not know if with amlogic flasher or when installing this rom from android 6 stock, the question is that I do not know how to install another recovery to install another Rom, I do not recognize windows the TV box to use adb or fastboot and install an image of the recovery and previously I only recognized it by pressing the button that has the box to enter the recovery, I do not know where to start.
I wrote here.Install the Root Rashr Flash Tool from the Playmarket.Open Root Rashr Flash Tool.Choose to install Recovery.Choose file twrp3.2.1.
Originally posted by khanhsac View Post
I need the file img, can you please give it?
1. su
2. dd if=/sdcard/twrp3.2.1.img of=/dev/block/recovery
3. reboot recovery
The first command for root
The second command passes twrp
The third command overloads in the new twrp3.2.1
In it and install zip file.
But better ask who knows how to install twrp in android.
If you are not sure, do not go!!!!!!!!
Backup to twrp.To return.
Ask for help in creating an image for downloading through the computer from these files to Ricky Diviacovsky XDA.
I installed oreo_8.0.0_by_levy yesterday. Flashing initially failed at 7% but after retrying it finished without errors. The OTA (10MB) flashed nicely too. The rom looks really nice, i'm not experiencing any bluetooth issues. The only "issue" i'm having is that it's sometimes hard to click a button with my flymouse, as mentioned by other people too, but since i'm mainly using netflix and kodi so controlling it with the arrow keys it a an issue.
I installed twrp.img (the one sagert hosted a link for on github) by clicking the twrp.img from ES file explorer, it opened rashr flash tool and installed nicely.
I am a bit confused though, about whether I should install v25 or v26, as per the instructions on sagert's github link. Android 8 by levy is working fine for me.
Any recommendation on if I should install v25 or 26? I'm mostly looking for a painless rom.
Kudo's for lewy20041 for this rom. I was thinking about replacing this "old android 6 box" but you've given new life to it ;-)
Originally posted by lassieee View PostI installed oreo_8.0.0_by_levy yesterday. Flashing initially failed at 7% but after retrying it finished without errors. The OTA (10MB) flashed nicely too. The rom looks really nice, i'm not experiencing any bluetooth issues. The only "issue" i'm having is that it's sometimes hard to click a button with my flymouse, as mentioned by other people too, but since i'm mainly using netflix and kodi so controlling it with the arrow keys it a an issue.
So, I played a little with v27. Flashing took some time but completed without errors. Upon first boot I got a popup "Android System - There's a problem with your device. Contact your manufacturer for details". After clicking "OK" I went through the setup wizard and configured my google account. The rom looks nice but I had a couple issues:
1) first thing to do is disable screen rotation, or else the homescreen will go 90 degrees counter clockwise
2) not able to move shortcuts on homescreen, or place installed app on desktop (but thats the same as on levy's 8.0)
3) screen goes off, like on a phone
3) unable to return to homescreen from apps. pressing esc or back on my flymouse doesn't work. In Levy's 8.0 I can just click the right mouse button on my flymouse to "go home" EDIT: i have a home button on my flymouse that gets me back.
4) text under installed apps on homescreen is cut in half. the bottom half is missing
5) swiping up from homescreen does not work
6) unable to boot into recovery with reboot apps
I'll be reflashing Levy's 8.0 as that is more stable for me. Thanks for your effort.
Originally posted by lassieee View PostSo, I played a little with v27. Flashing took some time but completed without errors. Upon first boot I got a popup "Android System - There's a problem with your device. Contact your manufacturer for details". After clicking "OK" I went through the setup wizard and configured my google account. The rom looks nice but I had a couple issues:
By the way, I launched android 9.To be continued.
yeah, you can also swipe down and click the screen rotation button to lock rotation. I was only stating my experiences. I used a reboot app to reboot/shutdown/boot to recovery, but that app hangs on "booting to recovery" in v27. I thought I had to reflash using the USB flashing tool, but the box rebooted to TWRP after holding the reset button, so i wiped everything and restored my 8.0 backup and all is good now.
Android 9?! sounds good!
There are currently 1583 users online. 4 members and 1579 guests.
