S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by andrew37 View Post
Try different ports... Maybe a better a-a cable. Once you get burn tool to see the device you're close.
#228.1Guest commented06 December 2018, 19:23Editing a commentThe latest version of the USB Burning Tool is 2.1.6.8. You can find it here: https://beelink-my.sharepoint.com/:f...xF0iA?e=OoUWKE
I am new here and after many hours of frustration and searching and troubleshooting I decided to sign up and post here in hopes that someone could help me.
I have a Nexbox A95X S905X 2G/16G. I spent a few hours trying to install Oreo by following this guide. My the USB burn tool (V2.1.2) would not see my device, no matter what I tried. I reinstalled the driver, I hit start and then plugged in the USB cable, both while holding the reset button and not. I tried every variation I could think of to no avail.
I then tried to install via the SD card, that failed almost immediately. I then installed an older version of the USB burn tool (V2.0.5.15 build 7) and it finally saw my A95X! It however failed to burn the image at 2%, I did some reading and unselected the Erase Flash and Erase Bootloader options and it kept failing.
For the sake of it I reinstalled the newer version of the USB burn tool (V2.1.2) and it saw my A95X and wrote the image without and issues.
Upon completion I plugged a display into the A95X and applied power. It showed "Android O by Levy" twice and then the loading screen with the four pictures circling and bouncing around. It stayed stuck on this screen for a long while, so I did some more reading, found the advice to unplug and replug power, which I did, and it still gets stuck on the loading screen, no matter how many times I cycle power.
I then tried to restart the A95X buy holding the reset button when applying power and where it used to go to a boot menu in the past, it now just shows the "Android O by Levy" and then loads indefinitely. I tried to create a bootable SD card and where that worked in the past it now still just shows the "Android O by Levy" and stops on the loading screen.
I am at a loss. I cannot get the tv box to do anything now and would truly appreciate any assistance available.
Thanks in advance,
-Bob
Originally posted by sagert View PostI made android 8.1 aosp with aosp_8.1_v25_phhusson.
Android 9.0 is unstable.
andrew37 There on github is written how to do in project.
1. Install android 8.0 Levi
2.Install twrp 3.2.1 what i did there is the address.
3.go to twrp and do it there wipe dalwik,cache,data,system
4.Install firmware zip file v25 there is a file address
Here is the exact address of the twrp and zip file
Opened firmware android 8.0 .This is a manifest for android 8.0 .Is it possible to edit it for downloading repositories for android 9.0? From the site of Amlogic the problem is downloading .The more because ssh.
manifest.xml.zip
Originally posted by sagert View PostOpened firmware android 8.0 .This is a manifest for android 8.0 .Is it possible to edit it for downloading repositories for android 9.0? From the site of Amlogic the problem is downloading .The more because ssh.
Sent from my Redmi Note 4 using Tapatalk
There are currently 4062 users online. 1 members and 4061 guests.
