S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
    Originally posted by lassieee View Post
    yeah, you can also swipe down and click the screen rotation button to lock rotation. I was only stating my experiences. I used a reboot app to reboot/shutdown/boot to recovery, but that app hangs on "booting to recovery" in v27. I thought I had to reflash using the USB flashing tool, but the box rebooted to TWRP after holding the reset button, so i wiped everything and restored my 8.0 backup and all is good now.
    Android 9?! sounds good!
    In android 8.1 v27 must be installed root Magisk .Therefore, the program did not go into twrp.We need to make backup and android 8.1 so that it can be returned to android 8.1 .
    Made an android 9.0 .Only there the system slows down a little.Probably little memory left.You can see for yourself.The instruction is almost the same.If Android 8.0 is installed and twrp then we skip it and set the rest.
    https://github.com/s1a1g1e1r1t/AOSP_...s905x/projects
    Although I do not remember what is there in v27.
      Will those ROMs work on Amlogic S905x boxes with ap6330 wifi chip?
      Sent from my ONEPLUS A6013 using Tapatalk
        Try it seems to me it is not very difficult.
          Correct.
          But shouldn't you as developer of the ROM know which WiFi chipsets softwares are baked in?
            Correct.
            I did port from images Project Treble phhusson.I was the main launch.
              Correct.
              Yours is not there.
                Ok, thanks
                  Hi Levy,
                  thank you for your rom, I just flash it to my x96 S905X devices but found out that the Wifi is not working, could you guide me how to fix it ? other than that your ROM is very nice :-)
                  thank you
                    Originally posted by monusan View Post
                    Hi Levy,
                    thank you
                    My X96 s905x works via cable Ethernet.
                    Instructions for creating android 9 for Amlogic s905x , s905x2, s805x
                      Installed on CQ II 1/8 only black screen.....
                        lewy20041 i have access to a multitude of different boxes. If you need me to test, find me on the cord or the node.
                          You have boxing with 1 gb memory.You only fit vanila v28 .
                          Choose it there option 4d .
                            Ok thanks! Ill give it a try'!
                            It is TWRP flashable only? So, boot into TWRP from option 2 (renameing to recovery.img) and then flash?
                            zip only contains boot.img, so how about bootloader and stuff?
                              If you have already installed Android 8.0 Lewy , then install it twrp
                              After installing it, go to twrp .And there clean wipe data ,system ,cache , dalwik .Then in twrp install zip file firmware
                              After reboot into the system.From and all.
                                hello! I think soldiaz says that he flashed your firmware and device don't boot peoperly. He can't go to next step to flash twrp. I have same story with my X96 1+8gb. Maybe you have vanilla v28 for USB Burning Tool ?
                                thanks anyway
                                upd. I've solve the problem. Install img on my x96 1+8gb device.
                                I can upload my moded img for owners with 1gb devices if lewy20041 allow.
