S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
I just checked and download is working fine. Maby server had meintance. Please try again.Everything is possible if we work together!
Nope, i dont think it will work with mibox.Everything is possible if we work together!
I opened the Levi firmware android 8.0 with the help of Amlogic Customization tool .It found a file in it manifest for android 8.0.It is necessary for compilation.I thought if it was edited on android9.0.In it replace the release dates and the letter o with p.On the site amlogic there is probably only for developers.Even through ssh.
DiogoSilva48
Originally posted by sagert View PostI opened the Levi firmware android 8.0 with the help of Amlogic Customization tool .It found a file in it manifest for android 8.0.It is necessary for compilation.I thought if it was edited on android9.0.In it replace the release dates and the letter o with p.On the site amlogic there is probably only for developers.Even through ssh.
DiogoSilva48
Originally posted by claishem View Post
so no more solution for bricked mi box 3 right?
only by removing the emmc and direct flashing it with ufi box.
Конечно, qualcomm - первый. Обязательно Amlogic в разделе поставщиков. Поэтому я не запускаю android 9. Здесь kmsg и dmesg.
kmsg + dmesg.zip
v26 l также работает на Android 8.1. Я разместил ее адрес на github, где и v25.Attached Files
Originally posted by sagert View Postandrew37 There on github is written how to do in project.
1. Install android 8.0 Levi
2.Install twrp 3.2.1 what i did there is the address.
3.go to twrp and do it there wipe dalwik,cache,data,system
4.Install firmware zip file v25 there is a file address
Here is the exact address of the twrp and zip file
https://github.com/s1a1g1e1r1t/AOSP_...s905x/projects
I am new to this so I am a little confused with instruction 3. I have already installed 8.0 Levy and the box is working fine. So not sure how I can install TWRP 3.2.1 which is also an image file? Can you send a link on how to install TWRP on an existing Android Image?
Also, do I need to install TWRP? Can I just install your img directly using the USB tool? Trying to figure out if having android 8.0 by Levi is requirement or not.
And finally, the download website is really slow. Can you put v26 on a faster server? Its showing me 4.5 hours to download 802 mb file.
Thanks.
There are currently 4004 users online. 1 members and 4003 guests.
