S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by soldiaz View PostYeah, would be awesome!!! What did you modify?
After unpack firmware in CT you will get a folder with unpacked firmware. In this folder find file _aml_dtb.PARTITION and replaced it with file from post.
After this pack fiirmware back via CT and flash it via USB Burning Tool
Originally posted by tragic_audio View Post
i use Customization Tools (CT) from set of software AMLogicTools and file provided by 01520717 from this post
Originally posted by sagert View Post
V6.0 Amlogic tool it does not correctly pack the firmware.It is necessary to know which version correctly packs.Or put the address here unpacked firmware.
i try different ways
Here my mod for 1Gb devices: https://mega.nz/#!l1gwTIYR!rA8mu0NRR...qGKOyp-EvngSYELast edited by tragic_audio; 13 February 2019, 19:55.
Maybe it was v.5.5.0
Originally posted by soldiaz View PostCan anyone confirm or clear up this:
If I have an dtb taken from Android MARSHMALLOW or NOUGAT image with working remote, is it possible to use this one for OREO then?
Or is it going to brick my box?
Originally posted by tragic_audio View PostHi, i think its must working. I dont do it by myself, but read about replacement this file often on other forums. People get stock remote.conf file and all works.
remote.zip
Originally posted by soldiaz View PostI know howto replace remote.conf. My question is wether there is some code in bootloader since I experi3nced a non working remote even with replaced remote conf
There are currently 1666 users online. 1 members and 1665 guests.
