S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
That is interesting. And I'm assuming you're connecting to the rear USB port of the TV box? The USB port next to the HDMI cable? I can't remember, but I may have flashed using the USB on the right side and that didn't work for me. And just to be sure you're also using a male-to-male USB Type-A cable at both ends, right? Lastly, I was using a v115. not sure if that matters or not.
Also, I'm not using WiFi. I have it connected to a RJ45 cable.
Originally posted by farzid View Post
Mine Box is Coolme MB1 based on same Mini M8S II , mine was also not detecting in USB burning tool ,i downloaded latest available USB burning tool v2.1.6 and then downloaded Universal ROM for S905X by minixfreak in the forum and used USB male to male connector to connect at backside USB port with reset button pressed .The Amlogic Usb burning tool detects it without pluging the DC power adapter .I think this may help you too.
Good call. That's what I did. I had the reset button pressed and inserted the USB in back port and no power cable. Computer recognized it right away, then release the reset button. I'm using Windows 10. if that helps.
Originally posted by blrdude39 View Post
Thanks farzid and metrometro. That sure help me to flash back a v113 beelink firmware and get my box though this time no WiFi but I see the display on the screen coming up and responding
by the way, so i also managed to dual boot my TV Box.I installed a linux version (Armbian - ubuntu) on a SD card. so I'm able to run a full desktop environment on a TV box. and amazingly runs pretty ok. YouTube suffers a lot though. lots a frame drops, but overall, pretty ok if just using a browser and listening to music. if I need to boot back in Android, I just pop out the SD card and it's back to Oreo...neat.
Hi great rom the tvheadend apk work with this room but the usb dvb not recognize, can you plase recompile the kernel with drivers, thank you very much, its from nividia shild tvheadend apk link: https://androidfilehost.com/?fid=818070582850487945Last edited by Fredhosi; 29 August 2018, 17:13.
Sorry to bother again. In an attempt fix the wifi issue I had with the v113 I used the AMPAK zip I found in one of the discussions on here but looks like my USB cable was on its last legs and did an incomplete burn bricking the device. What I have is a p212 board , sheep logo MINIM8S_II_V3.2_20161111 2G/16G with NAND SAMSUNG KLMAG2GE4A-A001. Only the red light glows. There is no blue light. USB cable or SD card method is not working. Does anyone have this specific board and know which pins to short for the NAND reset.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Hello, I have just installed this build on a Nexbox 95X box (S905X). Almost everything works great with excellent speed. Here are some of the issues I am seeing:
1) Youtube does not work. I have installed youtube.apk version 1.3_11 but it gives network error. I have also tried latest builds with same result. Is there any way to fix that network error?
2) I could not find the network settings for Ethernet. I am not using wifi and my box is hardwired. All other apps are able to access the internet just fine. When I start youtube, its funny that it plays an ad, and the ad works fine, but then when it has to play the video, it says connection reset or something like that. Any suggestions? Great build otherwise. I can now install 64 bit apps.
3) USB mouse is messed up. It works sometimes but most of the time the select is random. Thankfully my remote is working so I am all set
4) For some reason the resolution of most of the application is set to 720p. e.g. plex or Kodi show interface UI at 1280 X 720 max (and is greyed out). However, when I play any movie it shows in its native resolution like 1080p will show as 1080p and 4K will show as 3840 x 2160, etc. Is there any way to change the native setting? I have obviously tried changing the settings in the display but that does not seem to make any difference. Once again I would like to clarify that its just the UI interface of the applications that is rendered at 720p resolution.
I will repost if I see any other issues.
Originally posted by canbonbon View PostIs there anyway to do factory reset? That option seems to have been disabled.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If you can get into the Android Recovery, use the factory reset from there.
Originally posted by blrdude39 View PostSorry to bother again. In an attempt fix the wifi issue I had with the v113 I used the AMPAK zip I found in one of the discussions on here but looks like my USB cable was on its last legs and did an incomplete burn bricking the device. What I have is a p212 board , sheep logo MINIM8S_II_V3.2_20161111 2G/16G with NAND SAMSUNG KLMAG2GE4A-A001. Only the red light glows. There is no blue light. USB cable or SD card method is not working. Does anyone have this specific board and know which pins to short for the NAND reset.
Ok thanks. I will try that. Also, I am assuming its just me that does not have YouTube working. Is it working for you? Or is this a overall issue for the build? For some reason I think it is some kind of permission issue. Other apps that access Internet work just fine.
The other option is to install a VPN app and have it control the DNS settings. I might go that route if I am not able to figure this out.
There are currently 3407 users online. 1 members and 3406 guests.
