S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Ah, you are right. It must be some server issue. If it dont fix itself in few hours i will upload again.Everything is possible if we work together!
Will reupload in the morning once i have acces to pc.Everything is possible if we work together!
Guest
My ntfs external hd is "not supported" . Android asks me to format for use it as "portable memory". Kodi don't see it at all. Escuse for my bad english....
Someone will have to test it:" But i strongly recomend that only people with unbricking experience, tray it on devices difreant than Mini M8S II.
Added "mega.nz" mirror for downloads.Everything is possible if we work together!
Works great for Sunvell t95x 2/16
Found bugs: When scrolling in the settings when clicking on the item, a bug occurs, returns to the top of the list, you can not select 12 or another item below the list. You can not select the system language for your system.
While you can not use the firmware with the mouse, 7.1.2 is much more stable
Try using keyboard and arrows. There is a bug in framebuffer that is cousing this.Everything is possible if we work together!
I loaded this onto a Sammix R95S box (a fairly standard 2G/16G p212 board) but it wouldn't boot. The power light came on the box but there was no sign of any activity and the TV screen was blank with no boot logo. I flashed it a second time but got the same result.
The Sammix R95S is very similar to a Mini M8S II so it's odd it won't boot that image. If I get ambitious, I might pull out my soldering iron and get a serial console working so I can figure out what's wrong.
Originally posted by djvvb View PostI tryed it on my Sammix R95s 2/16GB and this error appear at 2%
[16:06:13 370][HUB3-3][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
Somebody know about it.
There are currently 1930 users online. 0 members and 1930 guests.
