S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Great work from one of our dev's lewy20041
Flashing all went fine 6.39 minutes to complete.
Booted up all good 3 minutes on first boot
Great clean looking rom with no crap
First OTA installed ok too
Bug's
No Bluetooth or WIFI on the Bqeel M9C Max as expected
Blinky
Thanks for testing
Later when the rom is striped out of bugs i plan to add multiple bt and wifi drivers.Everything is possible if we work together!
Hello. Great surprise for me that someone is still developing for this box. Kudos to you!!
I have a MINI M8S II.
I' ll help a liitle with bugs.
Already installed OTA 1.0.1.
So here is my list for the moment:
- No settings for ethernet.
- WiFi and BT are enabled each time you powercycle the box regardless if they were disabled.
- A bit weird behavior of the cursor. You can't press easily OK in confirmation messages.
- You can't add/delete apps in the bottom bar or transfer them to the home screen.
- Sometimes apps stop responding messages
- When in Settings--> Applications and while you choose an app by mouse the cursor goes to another app. Only with keyboard up/down keys you can choose correctly.
Working good:
- Fast booting.
- R/C
- HDMI CEC ( in my Philips TV with version 112 CEC wasn't working at all! )
- YouTube 4K ! (but the box froze once I changed from 4k -->1080)
- Google Play Store - OK
Suggestions:
MoviePlayer and PPPoE should be deleted from rom.
That' s all I remember for the moment. I' ll continue to search for bugs and I' ll post again.
Thank you once more for your excellent job!
Thanks for your findingsWill release ota once i fixed the pointed bugs.
Thank you, I want to try this rom on my Sammix R95s 2GB/16GB S905x (P212) to share the experience, but i need to make a backup of my firmware to back it up for any trouble. Somebody know where can i get it, or the way to make a full backup of my firmware.??
Thanks in advance.Last edited by djvvb; 21 March 2018, 16:04.
Hi
I installed on my Nexbox A95x 2/8Gb
it work fast but all time Bluetooth crash and display label on screen. Can't organize home screen and can't move screen icons and ad to bottom bar.
Now I can not installed other ROM by USB Burning tools. The program not detect the device when connect it by USB cable. Can't install TWRP by AV pushing button. Can some help me. I delete by mistake my backup file. Can someone upload backup file to try restore my old ROM by it.
Try shorting pins on nand to recognize the box with pc.
Its have default gxl bootloader so not sure why pc want recognize your unt.Everything is possible if we work together!
I think Amlogic gave up 8.0 and focused on 8.1
If I remember well... I am not 100% sure right now.Android TV Box direct from China. English & EspaƱol
@Javimetal
There is sdk for 8.1 from amlogic but i dont have acces to it. Once it will be avilible i wil share ota update.
@cobra1111new
Link is working just fine.Everything is possible if we work together!
Hm, maby try with difreant browser. For me its working fine. Can someone else check?Everything is possible if we work together!
There are currently 4259 users online. 1 members and 4258 guests.
