Thanks 01520717
S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Most likely also dtb is the couse.Everything is possible if we work together!
Guest
This is friggin awesome, lewy20041! Were you able to compile the Khadas VIM Source pretty much as is, or did it require a bunch of tweaks to work with the generic Amlogic p212 reference board?
There has to be some changes but not that much.
the most important chnge was in bootloader. There is a board check witch need to be disabled to get it work on other devices.Last edited by lewy20041; 11 April 2018, 08:50.Everything is possible if we work together!
Originally posted by lewy20041 View PostThere has to be some changes but not that much.
Originally posted by 01520717 View PostConsidering u-boot is compiled separately from the kernel and android, maybe a person could compile u-boot for the Amlogic S905X and compile the kernel and Android for KVIM. Theoretically this should work fine and it would save the time of having to manually edit the KVIM u-boot code and it would add some functionality like support for multiple DTBs to the bootloader. Whether it actually works in practice is a totally different question...
That method saves a couple of steps versus having to edit the kvim source before compiling u-boot. Plus by default it supports multiple DTBs so the image would work on a 1GB, 2GB or 3GB box.
Thanks to lewy for showing us oreo works on our Android boxes. Now we have something new to play with!
You could probably delete bluetooth.apk from system partition using twrp. Just place twrp(rename to kernel.img) and dtb.img on external sd or pendrive and reboot the unit.Everything is possible if we work together!
There are currently 2899 users online. 1 members and 2898 guests.
