S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Thanks... sunvell t95x 2/8 works good. Some mouse problem(in some apps scroling after few sec return position on start list) and bluetooth error(fix by freeze or delete bluetooth.apk), but impressive ui speed. Fresh kernel and u-boot, ota.... it's like happy birthday for s905x box's)Last edited by talraash; 27 April 2018, 11:52.
Hi everyone, Lewy thank you for this Rom!!
I have a Mini M8S ii box, it still has the original Rom it arrived with from Gearbest. Do I need to root it or do anything specific to it before I flash this Oreo rom onto it please or is it safe to go right ahead?
I plan on following this guide found on Youtube by the very helpful member Clarkss12 / Ronnie Bailey: https://www.youtube.com/watch?v=gaOuY94DGcU.
I've flashed plenty of Android phones before but this will be my first ever box so I'm just checking before i proceed!
Thanks,
D.
Hi to all.
For those having the bluetooth issue in lewy20041 rom, instead of uninstalling the apks just edit build.prop with the ESfile explorer and search for the line
config.disable_bluetooth=false
Edit to
config.disable_bluetooth=true
Save the file
Reboot the unit.
Done.
ESfile explorer must be granted write rights for system folders first. Search to activate it inside the application.
Hi everyone how has a bad batch of M8S Pro + (Plus),
I almost throw my new box M8S Pro + that had one of the bad batch's and was totally not able to strat e return to life... But now with this firmware it works! It has a bug for Bluetooth but I will refer to post #93 and perform from build.prom I am confident that it will work and now here you have a brand new box with Oreo on Top thanks to this man lewy20041 !Last edited by Shkumba; 01 May 2018, 08:35.
Originally posted by Shkumba View PostHi everyone how has a bad batch of M8S Pro + (Plus),
I almost throw my new box M8S Pro + that had one of the bad batch's and was totally not able to strat e return to life... But now with this firmware it works! It has a bug for Bluetooth but I will refer to post #93 and perform from build.prom I am confident that it will work and now here you have a brand new box for Oreo on Top thanks to this man lewy20041 !
Thanks for posting this.
MeCool M8S Pro +
I have loaded it on to my original Bad Batch Box and indeed it runs - Great.
but ...
a few little things ... had to install Solid Explorer to edit the build.prop (couldn't get ES to work) but build.prop doesn't have the above mentioned line in it ? not in the file I found ?? Editing in the line did nothing, so had to delete the bluetooth apk and now not getting the fail notice, which is nice.
Only the Filemanager app sees the USB thumbdrive I have installed.
ES, SE managers and both Kodi and SPMC can't see it as a drive for some strange reason ?
Nice to be able to see a USB drive ...
Difficult to get the file managers to hit the right file as they keep jumping on press ??
No Power button so I installed a simple Power Button app !
All in all way better than a box that freezes after 20 seconds, and very nearly really useable so BIG Thanks Lewy.
Heres hoping Magendanz or someone can make a nice ATV version as well.
Thanks again.
Will update the rom and fix the mentiined bugs once i get the android 8.1 sdk. Hope someone can share it with me sooner than later.Everything is possible if we work together!
MeCool M8S Pro +
but ...
Thanks again.
this is the folder which contains the build.prop that needs editing to
This will eliminate the Bluetooth error message.
Cheers
Originally posted by Jgon View Post
/Vendor
Cheers
Amateur here, didn't know there was more than one build.prop
To get it working on mecool m8s+, is it important to edit dtb? Or will it work out of the box with 2gig ram?
edit:
And what is with wlan. Is it working?Last edited by blackThirteen; 01 May 2018, 19:30.
Originally posted by blackThirteen View PostTo get it working on mecool m8s+, is it important to edit dtb? Or will it work out of the box with 2gig ram?
edit:
Ethernet only and need to stop Bluetooth as noted.
WIP but at least get a working box from a Bad Batch Box !
Worked out of the box - but no wifi.
So I just tried this Oreo image, and it just flashed perfectly in one go! I almost was going to throw this box away
I don't know why this firmware works? Maybe it's better compatible with the Samsung NAND?
Thanx lewy20041 !
There are currently 3273 users online. 3 members and 3270 guests.
