S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
    Android Oreo
    Tested with Mini M8S II
    (Possible to work on other GXL/S905X boxes. Testing needed)
    Click image for larger version  Name:	Screenshot_20180310-115228.png Views:	2 Size:	234.8 KB ID:	713970
    Click image for larger version  Name:	Screenshot_20180314-142852.png Views:	1 Size:	100.1 KB ID:	714381
    Click image for larger version  Name:	Screenshot_20180310-115241.png Views:	2 Size:	88.5 KB ID:	713969
    Click image for larger version  Name:	Screenshot_20180310-115317.png Views:	1 Size:	33.6 KB ID:	713971
    Stock remote colour buttons:
    *Red - Screenshot
    *Green - Music App
    *Yellow - Browser
    *Blue - Recent Apps
    What is working:
    - WiFi
    - Ethernet
    - Bluetooth
    - USB
    - MicroSD Slot
    - Playstore
    - Remote
    - CEC
    - Passtrough (also in official kodi 17)
    - Adjust Refreash Rate (tested in spmc 16.7.4, mediacodec surface disabled)
    - Led
    - Power Off
    - Sleep
    - StatusBar, NavigationBar
    *fully immersive, just swipe from up for statusbar and from down for navigationbar
    - Ota Updates
    - Etc.
    Whats not working:
    - Webcams (not working with stock camera but works with USB Camera app in playstore and probably more similar apps)
    link to camera app https://play.google.com/store/apps/d...sbcamera&hl=pl
    - Mic (Same as webcams)
    Whats new:
    - 64bit
    - New bootloader compiled from source
    *selinux permisive
    *auto multiboot function:
    (example: -libreelec- just put kernel.img and dtb.img to boot from external devices like sdcard or usb)
    (example: -armbian- to boot linux the bootloader will serch for s905_autoscript on sd or usb)
    - init.d support
    - Youtube 4K60FPS
    - New kernel compiled from source
    - Firmware build with sdk
    - SystemUI Tuner
    NavigationBar will be disable by default becose some apps are not compatible and dont scale properly,
    to enable it just remove # in build.prop from #qemu.hw.mainkeys=0
    As Android Oreo for S905/S905x is quite new there may be some bags.
    I will also make Oreo for first generation of Mini M8S with S905 procesor.
    What bugs? I cant find all bugs by myself so, if there is a bug please report and i will try to fix it for future versions.
    Firmware is Rooted.
    Also i changed the default UI resolution to 720p for performance.
    If you wish to have UI in 1080p you need to change /vendor/mesondisplay.cfg and also /system/build.prop lcd.density to 240. Later will add switch to change ui resolution in the firmware. And also ota updates.
    Download:
    LINK
    Use latest "Burning tools included"
    (All Donations even small are really appreciated)
    Everything is possible if we work together!
    ApkFreak
    Nice one Lewy
    another Freaktab First O on Tv Box. Way to keep us on the leader board..... now I'll have to dig that box out again Thanks lmao...
      Glad to see you back Lewy, always enjoy your builds.......
        Thanks,
        Updated few things today, like working led, youtube 4k, more apps compatible with playstore and some other things i dont remember Rom should be up in few days.
        ApkFreak
          Sounding very good Lewy.......
            Nice work m8!
            wait a bit more and you should have 8.1 available in a few weeks (i have it but cant share it because of work )
              Sadly i dont have acces to 8.1:" when i get sources for 8.1 i will release ota update so the users will be able to update stright from the box. Will add update future to the rom before relising it.
              ApkFreak
                  First post updated with download link.
                  Testers needed!
                  ApkFreak
                    Installed it on my X9 box, same as the Mini M8S 2. Burning it to my box, using the provided burn tool in your zip worked perfectly, took a little over 5.5 minutes to burn. Connected it to my TV, but now it is hung up in the loading screen, 4 colored circles going round and round. Will wait for a few more minutes and try again........
                    Edit. Pulled the power plug and plugged it back in, working now.......... Will set it up and post a video............. thanks.
                    Edit 2: All I can say is "WOW", it is fast. It downloads my apps from the Google Play Store fast.
                    Edit: Video showing how it works.
                    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                      Very nice video Also CEC in settings is for control the unit with tv remote.
                      ApkFreak
                        Looking good indead,
                        Installed on Mini M8S
                        First boot sat and hung Like in Clakies Vid, pull power all good.
                        Setup easy, good updates etc,
                        Even an OTA already excellent
                        Using Logitech k400 not 100% smooth, with mouse and left click sometimes jumps about....more checking to be done on that
                        Remote as seen in Video ok.
                        Can't add widgets message touch and hold,
                        How to drag Apps from from list to Lower Bar ?
                        Snappy indeed,
                          Ok, noted. Will try to do something about cursor in leter versions. As to the launcher you can try any other from playstore it should be fine. Maby i will fix this for next versions or just replace with difreant one.
                          Thanks for pointing out the bugs. It will help future development
                          ApkFreak
                            Will tinker about see what other unknowns can be found, looks great
                            Yes a different launcher, easiest fix
                              Just wanted to say thanks to lewy20041 and the testers, I will this a shot when I get a chance.
                              Does this rom have the brightness 'fix'?
