S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Hm, this may probably hapen becouse non standard gxl dtb for this boxes.Everything is possible if we work together!
Guest
Originally posted by lewy20041 View PostHm, this may probably hapen becouse non standard gxl dtb for this boxes.
I hooked up a serial console but didn't see any output from it so I'm beginning to wonder if something is preventing the bootloader from loading. I'll do a bit more testing with another ROM to make sure the serial console is working properly.
Hm, that strange. If that so it should work just fine. If you will be able to get some output from serial console please pos it here.Everything is possible if we work together!
Originally posted by djvvb View Post
Thanks for reply, I use the number 1 (the most nearly), but I used too on this same usb port and I can install another firmware and worked perfectly. I don't understand the problem.
I finally figured out why my serial console wasn't working... Iwithout thinking I connected Rx on my serial reader to Rx on the board and Tx to Tx. Once I realized that and fixed it, the serial console worked fine.
Here's the output from the failed boot on my Sammix R95S. There are several errors early in the boot process but it seems to continue to load the kernel, ramfs and dtb but it aborts shortly after that.
I'll compare this to a good boot of a Marshmallow image to try find out which error messages are important and which ones can be ignored.
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:0;READ:0;0.0;CHK:0;
TE: 135943
BL2 Built : 15:56:15, Nov 21 2017. gxl gfa7b794 - zhongfu.luo@droid12
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 912MHz - FAIL
DDR3 chl: Rank0 @ 912MHz
bist_test rank: 0 1b 01 35 2e 13 49 1a 00 35 2d 12 48 19 00 32 2d 11 49 18 00 30 2e 12 4a 676 - PASS
Rank0: 1024MB(auto)-2T-13
AddrBus test pass!
-s
emmc switch 3 ok
Authentication key not yet programmed
emmc_rpmb_key_is_programmed: error 0x00000007
emmc switch 0 ok
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0003b600
Load bl33 from eMMC, src: 0x0005c200, des: 0x01000000, size: 0x00068200
NOTICE: BL3-1: v1.0(release):a75d708
NOTICE: BL3-1: Built : 17:16:24, Nov 22 2017
[BL31]: GXL CPU setup!
NOTICE: BL3-1: GXL normal boot!
NOTICE: BL3-1: BL33 decompress pass
mpu_config_enablek
[Image: gxl_v1.1.3255-1a77b01 2017-09-15 16:58:02 xiaobo.gu@droid12]
OPS=0x82
32 66 f 2e 86 c7 18 73 76 eb ac 36 [1.189804 Inits done]
secure task start!
high task start!
low task start!
ERROR: Error initializing runtime service opteed_fast
U-Boot 2015.01 (Mar 07 2018 - 10:19:00)
DRAM: 1 GiB
Relocation Offset is: 36eaa000
register usb cfg[0][1] = 0000000037f55da8
[CANVAS]canvas init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000033eaa6b0
aml_priv->desc_buf = 0x0000000033eac9d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
original ext_csd[171] USE_WP field value is 50
ext_csd[171] USER_WP filed value after switch is 58
init_part() 293: PART_TYPE_AML
[mmc_init] mmc init success
start dts,buffer=0000000033eaf200,dt_addr=0000000033eaf2 00
get_partition_from_dts() 103: ret 0
parts: 14
00: logo 0000000000800000 1
01: recovery 0000000001800000 1
02: misc 0000000000800000 1
03: dto 0000000000800000 1
04: cri_data 0000000000800000 2
05: param 0000000001000000 2
06: boot 0000000001000000 1
07: rsv 0000000001000000 1
08: tee 0000000002000000 1
09: vendor 0000000010000000 1
10: odm 0000000010000000 1
11: system 0000000074000000 1
12: cache 0000000046000000 2
13: data ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
check pattern success
mmc env offset: 0x4d400000
In: serial
Out: serial
Err: serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-1078: calc 80840c53, store 80840c53
dtb_read()-1200: total valid 2
dtb_read()-1267: do nothing
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpu: vpu_clk_gate_init_off finish
vpp: vpp_init
hpd_state=0
cvbs performance type = 6, table = 0
Net: dwmac.c9410000amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
MACADDR:02:73:76:eb:cc:dd(from chipid)
Warning: dwmac.c9410000 MAC addresses don't match:
Address in SROM is 9e:2a:75:e6:aa:bb
Address in environment is 02:73:76:eb:cc:dd
Start read misc partition datas!
info->magic =
info->version_major = 0
info->version_minor = 0
info->slots[0].priority = 0
info->slots[0].tries_remaining = 0
info->slots[0].successful_boot = 0
info->slots[1].priority = 0
info->slots[1].tries_remaining = 0
info->slots[1].successful_boot = 0
Magic is incorrect.
boot-info is invalid. Resetting.
save boot-info
info->magic =
info->version_major = 1
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=2
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x7f800000
[CANVAS]addr=0x7f800000 width=3840, height=2160
amlkey_init() 71: already init!
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
saradc - saradc sub-system
Usage:
saradc saradc open <channel> - open a SARADC channel
saradc close - close the SARADC
saradc getval - get the value in current channel
saradc test - test the SARADC by channel-7
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
Hit Enter or space or Ctrl+C key to stop autoboot -- : 1 0
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
card out
[sd_inand_staff_init][246], debug
emmc/sd response timeout, cmd1, status=0x1ff2800
(Re)start USB...
USB XHCI 1.00
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33f2f450
copy done
Kernel command line: otg_device=0
load dtb from 0x1000000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x026e1a00
Loading Ramdisk to 33ce0000, end 33e981a8 ... OK
Loading Device Tree to 000000001fff1000, end 000000001ffff2f4 ... OK
fdt_instaboot: no instaboot image
Starting kernel ...
uboot time: 5400019 us
[ 0.000000@0] Booting Linux on physical CPU 0x0
[ 0.000000@0] Linux version 4.9.61 (lewy@ubuntu) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #36 SMP PREEMPT Tue Mar 13 12:53:46 CET 2018
[ 0.000000@0] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000@0] earlycon: aml_uart0 at MMIO 0x00000000c81004c0 (options '')
[ 0.000000@0] bootconsole [aml_uart0] enabled
[ 0.000000@0] Bad mode in Error handler detected on CPU0, code 0xbf000000 -- SError
[ 0.000000@0] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP
[ 0.000000@0] Modules linked in:
[ 0.000000@0] CPU: 0 PID: 0 Comm: swapper Not tainted 4.9.61 #36
[ 0.000000@0] Hardware name: Amlogic (DT)
[ 0.000000@0] task: ffffff800a578700 task.stack: ffffff800a560000
[ 0.000000@0] PC is at setup_arch+0x108/0x5a4
[ 0.000000@0] LR is at setup_arch+0x104/0x5a4
[ 0.000000@0] pc : [<ffffff800a113b28>] lr : [<ffffff800a113b24>] pstate: 000000c5
[ 0.000000@0] sp : ffffff800a563f10
[ 0.000000@0] x29: ffffff800a563f10 x28: 0000000002110018
[ 0.000000@0] x27: 0000000037f5fb58 x26: 0000000033eaf848
[ 0.000000@0] x25: ffffff800a569000 x24: 0000000000000000
[ 0.000000@0] x23: ffffff800a569000 x22: ffffff800a6e5000
[ 0.000000@0] x21: ffffffbefe9f1000 x20: ffffff800a5ab000
[ 0.000000@0] x19: ffffff8009080000 x18: 0000000000000027
[ 0.000000@0] x17: 0000000000001810 x16: 0000000000001000
[ 0.000000@0] x15: 0000000000001c00 x14: 0000000000000000
[ 0.000000@0] x13: 0000000000000007 x12: 0000000000000010
[ 0.000000@0] x11: 0000000000000004 x10: 0101010101010101
[ 0.000000@0] x9 : fefefefefefefeff x8 : 7f7f7f7f7f7f7f7f
[ 0.000000@0] x7 : 687564635e66736e x6 : 0c1b092c0b091369
[ 0.000000@0] x5 : 6913090b2c091b0c x4 : 0000000000000000
[ 0.000000@0] x3 : 0000000000000000 x2 : 00000000000000f7
[ 0.000000@0] x1 : 0000000000000000 x0 : 0000000000000001
[ 0.000000@0]
[ 0.000000@0] Process swapper (pid: 0, stack limit = 0xffffff800a560020)
[ 0.000000@0] Stack: (0xffffff800a563f10 to 0xffffff800a564000)
[ 0.000000@0] 3f00: ffffff800a563f90 ffffff800a1108d8
[ 0.000000@0] 3f20: ffffff800a1853a8 ffffff800a569000 ffffff800a6e5000 ffffff800a6e5000
[ 0.000000@0] 3f40: ffffff800a569000 0000000000000000 0000000000000000 0000000033eaf848
[ 0.000000@0] 3f60: 000000001fff1000 0000000000000001 ffffffffffffffff 0000000000000000
[ 0.000000@0] 3f80: 0000000000808080 000000000004093d ffffff800a563ff0 ffffff800a1101f8
[ 0.000000@0] 3fa0: 0000000034d5d91d 0000000030d00800 000000001fff1000 0000000000000000
[ 0.000000@0] 3fc0: 0000000000000000 0000000000000000 0000000000000000 000000001fff1000
[ 0.000000@0] 3fe0: ffffff800a1853a8 0000000000000000 0000000000000000 0000000001ca42bc
[ 0.000000@0] Call trace:
[ 0.000000@0] [<ffffff800a113b28>] setup_arch+0x108/0x5a4
[ 0.000000@0] [<ffffff800a1108d8>] start_kernel+0xbc/0x3f0
[ 0.000000@0] [<ffffff800a1101f8>] __primary_switched+0x74/0x8c
[ 0.000000@0] Code: 9134c000 940036e9 97fff32a d50344ff (d5384100)
[ 0.000000@0] ---[ end trace f68728a0d3053b52 ]---
[ 0.000000@0] Kernel panic - not syncing: Attempted to kill the idle task!
[ 0.000000@0] ---[ end Kernel panic - not syncing: Attempted to kill the idle task!
Looks like dtb issue:"Everything is possible if we work together!
You need to remember that oreo is using kernel 4.9 instead of 3.14 so there will be many difreances there to.
As you say you can compare the two from marshmelow or nugat and find the difreance and aply some changes to dtb from this rom if you are familiar with linux dtc tool. Also once done makeing changes to dtb you can test by placing boot.img (rename to kernel.img) and dtb.img on sdcard or usb (try difreant ports).Everything is possible if we work together!
I compared the Mini M8S II dtb from the rv112 firmware to the dtb from the R95S and they are very similar. Here is a UNIX diff of the two dts files. It's odd they are so similar and yet the R95S can't load the Mini M8S II Oreo image.
I can apply these changes to the Oreo DTB and see what happens but I suspect there is something more wrong than the changes shown below since none of these differences seem that significant.
< is from Mini M8S II
> is from Sammix R95S
687,689c687,689 (these are audio pins)
< amlogic,setmask = <0x6 0x10000000>;
< amlogic,clrmask = <0x6 0x8000000>;
< amlogic,pins = "GPIOH_4";
> amlogic,setmask = <0x10 0x10>;
> amlogic,clrmask = <0x10 0x8000000c>;
> amlogic,pins = "GPIOAO_9";
1032a1033,1048
> standbyled {
> compatible = "amlogic, standbyled";
> dev_name = "standbyled";
> status = "okay";
> led_gpio = <0x18 0x4b 0x0>;
> led_active_low = <0x1>;
> irled {
> compatible = "amlogic, irled";
> dev_name = "irled";
> status = "okay";
> led_gpio = <0x18 0x4c 0x0>;
1430c1446 (this is the system partition size)
< size = <0x0 0x60000000>;
> size = <0x0 0x40000000>;
1907,1910c1923,1926
< key_num = <0x1>;
< key_name = "power";
< key_code = <0x74>;
< key_pin = <0x69 0x2 0x0>;
> key_num = <0x2>;
> key_name = "power", "recovery";
> key_code = <0x74 0xf9>;
> key_pin = <0x69 0x2 0x0 0x69 0x3 0x0>;
1912a1929,1939
> adc_keypad {
> compatible = "amlogic, adc_keypad";
> status = "okay";
> key_name = "recovery";
> key_num = <0x1>;
> key_code = <0xf9>;
> key_chan = <0x0>;
> key_val = <0x0>;
> key_tolerance = <0x28>;
I was working on another project when I realized why this isn't loading on my Android box.
In the boot log, I noticed I have one of those boxes that was sold as having 2GB RAM but only one rank is recognized so only 1GB is usable. I edited Lewy's DTB for 1GB of RAM and now it runs fine on my box.
If Lewy's image won't boot on your box, use the Customization tool to unpack the first level then replace the _aml_dtb.PARTITION with the one attached here and repack the image. Then it should run on your box. I even took Lewy's update and it applied fine, i.e. it didn't change the DTB.Attached FilesLast edited by 01520717; 02 April 2018, 15:23.
There are currently 2723 users online. 1 members and 2722 guests.
