S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
    will this work for tx5 pro with 9377 wifi .... i know it works on tx5 pro just want to know if it supports qca9377 wifi
      I tried installing this on a X96 1G/8G. Attached is the boot log and the kernel panic. Let me know if there is anything else I can send you.
      Cheers,
      Chris
        Flashed to my KM8 S905X Box, my main issue being the KM8 OEM remote doesn't work plus the BT issue. But using mouse and keyboard been able to finally load 64 bit Lodi alpha1.
        If someone can help me get the OEM remote working against, it would be Great, Thks
          TYPO
          S905X 2/16, Kodi 18 alpha1, also having to use up down left right on kbrd instead of selecting w/ mouse
            Cheers,
            Chris
            The DTB lewy included with the Oreo image is only for 2G RAM boxes. I posted an edited DTB for 1GB boxes earlier in this thread. You can do a first-level unpack of the Oreo image and swap DTBs then repack and hopefully that will make an image that boots on your box.
            Last edited by 01520717; 22 April 2018, 05:47. Reason: Thought I should mention to only unpack first level since second level most likely won't pack properly
              The DTB has the remote definition in it. You'd have to take the remote.conf for your box and add those definitions into the DTB to get your remote working.
                Levy ROM works nicely on the Le Potato S905X CC (LibreComputer).
                Does anyone know which WIFI dongle to use?
                For the developer, could you compile with more wifi hardware options. I have some WIFI USB dongles but none seems to work out on the Le Potato.
                  will placing the remote.cofg in the etc folder get my remote going ? read up on this someware...
                  Thks...
                    my Km8 is 64bit S905X with 2G + 16G, not 1G ...Thanks, will look into the DTB...
                      will this work on my m9+ box
                      You may only view thumbnails in this gallery. This gallery has 4 photos.
                        Thks...
                        Unfortunately, Oreo no longer supports the use of a remote.conf file in /etc.
                        By default, Android versions from Nougat onwards have the remote definitions in the DTB. If you decompile it to a DTS, you can search for "keymap" and you'll find the remote definitions.
                        I've seen some Nougat ROMs that have some kind of app installed that allows a person to continue using remote.conf files in /etc. I've never looked to see which app they're using but I've seen it in more than one ROM so it must be something fairly common.
                          Yes, it most likely will run on your box but there are a few changes you'll have to make
                          - You'll have to replace the DTB with the 1GB RAM version I posted earlier in this thread
                          - Your remote and Wi-Fi probably won't work unless you add support for them to the ROM
                          - As with most ROMs, you'll have to leave the box on all the time because if you shut it off, the remote won't turn it back on; you'll have to pull the power plug to restart it
                            lewy20041 grateful for any instructions on adding WIFI USB support to your ROM.
                              Tried flashing the image using etcher on a MacBook and get the following error message: "It looks like this is not a bootable image. The image does not contain a partition table and may not be recognized or bootable by your device."
                              I went ahead and flashed anyways, inserted SD card into Le Potato and get nothing on the screen. Is this a simple fix? Any suggestions? Thx
                                The .img is to use with Amlogic Burning Tool only. It want work with Etcher.
                                Everything is possible if we work together!
                                ApkFreak
