S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
Originally posted by soldiaz View PostThanks! I guess I will try it!
I am still thinking of one thing:
There are Nougat DTBs without customcode (=factorycode) inside BUT with etc\remote.conf....
The DTBs with customcode inside do not have etc\remote.conf but have (in my case) remote_mouse1.tab, remote_mouse2.tab in etc\
Maybe, if customcode is missing in DTB then device looksup etc\remote.conf?
I just unpacked and made a screenshot....this is contents of level 2:
Windows says it is .sys file?
When opening as txt file this is content: !<symlink>ÿþ/ v e n d o r
Curious....I thought I could open it yesterday as txt file and it showed some chinese chars...like this:
xxxxxxx\vendor...weired ..maybe I dreamed of it lol
01520717 any idea how to manage to loadup remotecfg to be able to load old remote.conf?
That file is a symlink to vendor partition. Thats how it works in oreo.As to remote.cfg it wont work in this rom. Buttons mappings are hardcoded in dtb.Everything is possible if we work together!
If you look at the Poison ROMs, they run remotecfg as a service. If I remember right, it is defined in init.amlogic.rc.
The problem with going this route is that you'll have either find a copy of remotecfg that's compiled for the kernel version used in lewy's ROM or you'll have to find the source code and compile it yourself. I've never looked for the source code so I don't know if it is publicly available.
Originally posted by soldiaz View Posthow to use?
[QUOTE = soldiaz; n768173] stane1983 : Не могли бы вы добавить дополнительную информацию о github для amremote и о том, как его использовать. Может ли это быть полезным при работе с жестко закодированной удаленной информацией? [/ QUOTE]
Я перешел на новую. Мне нужно использовать ее в Ubuntu. Есть использование
remote.cfg
Excellent ROM!!! Very pleased with it. It brought new functionality to my X9 - I can stream with HBO Go now.
One major issue that I have... When in Titanium Backup, I want to use my external microSD card as the backup location. Whenever I try to change it to external microSD (TB --> Menu --> Preference -->Backup folder location --> (click to change) --> DocumentProvider storage ) it returns to TB home page. I can not select the external microSD card. Also, when I go into Setting --> Storage and select my external SD card, I get a dialogue box indicating that "Settings has stopped".) How to fix? (I tried reloading ExternalStorage Provider by clicking on the apk and even loading it with TWRP. Nothing changed.) Had the same problem when I formatted the external microSD as extended memory -- I would prefer microSD to be formatted as Portable storage.) I downloaded your zip file 4 times, and reloaded the image on my X9, and have the same issues. Please help. Thanks in advance.
BTW, using ATV Launcher (free verison) and it works great with this ROM.Last edited by razpuli; 05-03-2019, 17:53.
There are currently 1778 users online. 4 members and 1774 guests.
