S905X Android 8.0 Oreo (Tested on Mini M8S II. Possibile to work on other GXL/S905X boxes. Testing needed! "WIP")
    Wow awesome! Which wifi chip is supported?
      8189 and possibly ap6330.
        Really?? Ill must check it
        Oh no...I have RTL 8723BS
          Here you can install root rights with the help of magisc v19.3.Then maybe throw the wifi drivers into the vendor section.It may work.Root rights are set in this way.
          1.Download the magisc file that you need to install in the recovery.
          2.Install this file using Update&backup.
          3.Install Magisc Manager apk.
            Tested it today on a Mini M8S II S905X with WIFI AP6255 chip and I like it..... will updated once I have played with the ROM properly
              sagert ,can you post some screenshots of your android 8 and 9 rom, please?
                Originally posted by canadien View Post
                sagert ,can post some screenshots of your android 8 and 9 rom, please?
                This is from the android 9 traces.
ID:	787356Click image for larger version
ID:	787357Click image for larger version
ID:	787358Click image for larger version
ID:	787359Click image for larger version
ID:	787360Click image for larger version
ID:	787361Click image for larger version
ID:	787362Click image for larger version
                  Great, thanks! I have not read everything, but at the beginning you said pie was slow on s905x with 2GB. Was there any improvement since then? It's my last question... :-)
                    Serial android 9 works fine.I made this firmware from the superceleron firmware.For which he thanks.I used to do it myself.
                      Ok then since it's now based on superceleron's rom, does the installation has changed for android 9? I am currently on Lewy 8.0 firmware on a Mini M8S box. Is it simply a USB burning tool installation or I still have to go through the whole process (TWRP install, etc.)
                        On 37 page post 555 download the firmware.I made 2 firmware.Install using usb burning tool v 2.1.7.Everything is changing.I couldn't do firmware before.Now i can do differently.
                          Didnt anyone post the tx3 mini ATV9 link here?! Maybe I just dreamt of?!
                            soldiaz
                            Originally posted by xmannamviet View Post
                            Android TV 9.0 for X96 Mini release in Vietnam by Shop Boxtruyenhinh.com https://www.facebook.com/groups/7584...8995928811932/
                              On https://daivietpda.com
                                Guest thanks
