X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
Originally posted by Nixcore View Post
I belived i post it earlier, but this what i find:
Build number : rk3399_box-userdebug 7.1.2 NHG47K eng.foxluo.20181024.090531 test-keys
Build date UTC : 20181024-010531
And tried "MaskRomMode" with no luck.
not sure why it not works , but sure that your Rom is until now the latest , we shall find a Way ,
maybe your Seller can upload the latest StockRom somewhere , have Fun , gefattern
Originally posted by hezzy View PostHi, different thread but check out. https://forum.freaktab.com/forum/tv-...remote-control. Doesn't make sense that the 64gb version is cheaper than the 32gb one unless it has something extra. Its also called X99-4G.
yes there are different Box Versions of the X99 , but until now most Users bought this Version
here , maybe it is cheaper because the Company wants to get rid of the Boxes they still have in
Storage , greetings / gefattern
Hi ,
no Panic , your ordered X99 will do the Job , where did you bought it ???
Banggood. More an impulsive buy than compulsive! Seduced by You tube reviews of the X99. ?86 using Elec code. Probably won't receive it until the New Year.
Originally posted by gefattern View PostHi ,
once more , the Seller on Ali... says the Wifichip they use is AP6255 ,
hope no lie , think i gone buy one ,
they sell it for about 129Dollar (with DHL) / Box only / 103.5 Dollar
Do you have a rk3399 now?
Or, were you thinking of n6. I am Just curious.Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View Post
You did buy a X99.?
i have a X99 , runs not bad , of course some Bugs , but i only need the Box for
Gaming / Internet , for that is it good enough , greetings / gefattern
i gone test if i can backup my .img with AT , i already did it , but maybe the new Tools
do not support it , or it is a Bug , if i know more i post the results ,
Hi guys
for my past experiences of the Internet performance
Devices('Iv already used)
With WiFi;
>RK H96+ not bad but I do not liked
>X99 not bad but I do not liked too
>N6 good!
but all of these devices with WiFi "weak" performance!
With "Ethernet";even not bad!! I always prefere Ethernet connection,but still cant get it high performance!
for all X99 User , remember X99 has DDR3 , not DDR4 , like some newer Boxes use ,
so if some of the X99 Users want to flash other RK3399 Roms , remember this !!!
For moment, how to explain my wife to use Kodi on HDMI input 4, not the old Venztech V10 Box
"Unrooted" X99 does not work on KODI 17/18!!
"Trick for unrooted with Kodi use"(I mean 17,6 but 18 not work stable)
If you do not "OFF"(power) your device than never lost your Kodi!!
If you get OFF than all your Kodi Addons+Settings etc., FLY
So dont do it OFF! if your device getting off than you should install all your Addons+Settings
After than we flashed(Rooted SU version) KODI start to work(17/18)!
And for the latest OTA WiFi version than KODI works good!
So if you want to work with KODI than you need Rooted version!
Bye++
There are currently 1959 users online. 0 members and 1959 guests.
