X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    Originally posted by majdi qurony View Post
    Can you explain please ?? how to do it for X99 ??
    Hi ,
    first we need more Info about your Box , does it still work , please explain ,
    what happens when you connect it to TV ??? and what does the Flashtool
    say if you connect (as always) to PC ??? ,
    greetings / gefattern
      The 20181024 Firmware works great on my X99 rk3399 tv box. Use the RK android tool v2.43 UPGRADE FIRMWARE TAB. need the 3.0 small USB cable and the USB to USB big cable to work.
      Make sure you plug the small USB cable into the 2.0 USB on your computer. Haven't had any issues with the firmware at all.
        Would like to find TWRP for the X999, have looked everywhere.
          The 20181024 firmware is ROOTED.
            Hi ,
            we know , but is SuperSU installed , what Rom was installed on your X99 before ???
              No SuperSU not installed as an app. When I got box it wasn't rooted and run very bad. Had firmware 20180624 on it.
                Plugin the small 3.0 USB cable first into the box. Then hold the reset button and plug USB(big) to USB (big) into 2.0 USB on your computer and other end into the box while holding reset button. You will hear a sound knowing your box is connected. hen startup the RK android tool v2.43, load the firmware and hit upgrade.
                  Hi ,
                  Its X99
                  and when ever im connecting the device to the TV it wont start (NO SIGNAL)
                  please let me know if u need more details
                  thank you
                    Its X99
                    thank you
                    Hi ,
                    so you have a X99 , please what Rom did you use for flashing ???
                    what does the Flashtool say if you connect it to PC ??? , this is very
                    important to know , so please try and report , thanks ,
                      Hi ,
                      Hi
                      its EBox R99 7.1.2 Rom
                      For Flashtool whatever the tools its the same respond ( device not connected)
                      I tried 3 Flashtools ( AndroidTool_Release, FactoryTool and RockChip_Batch_Tool_v1.8 )
                      thanks
                        Hi ,
                        so you flashed this wrong Rom to your Box & you are sure you did the connect to Pc correct ,
                        with no results , so please download the latest Version from here , on Page 44 or 45 , to get
                        your Box restore you must open it up and get the PCB out , please make two good Pictures
                        as possible , one from each side and post them here , then we can go on , thanks
                          Hi
                            Hi
                            [ATTACH]n760260[/ATTACH]
                            Hi ,
                            Pictures looks like the same from first Pages , so we can be sure you really have the same
                            Box , now we must find the right Points to get your Box in MaskRomMode when connected
                            to Pc , at the Moment i am not really sure which one , but i think we can find it somewhere
                            here in Thread , so please be patient and wait till we exactly know they are correct , please
                            read as possible the hole Thread to find info we need , i search too ,
                              Hi again ,
                              maybe a Upgrade over SDCard works , did you already tried this , it is discribed
                              somewhere here too , greetings / gefattern
                                need to short the pinout to enter maskrom mode
