so x99 maybe cant use.
X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
FYI;do not flashed with 20181217(N6 MAX FW) cause of a lot of BUGs/Issues etc.,!!
and mine FW dated(now) 20181217
I'v N6 MAX this device BUG champ!
Before I'v used(about months) X99 and sold it!
And got fm GB partial-refund($ 42)
RK3399 very good but all RK3399 devices a lot of issues and never fix it!
Originally posted by majdi qurony View PostAfter flashing X99 stop working
I tried SD and USB tool nothing worked
any advice?
so you flashed N6 Rom to your X99 , correct ??? , only chance is to flash new ,
what happend when you connect to Flashtool & PC , any reaction of Tool ??? ,
you only can try to restore in MaskRomMode , but please first some more Info
about "brick" flash with N6 Rom ,
greetings / gefattern
Originally posted by guner67 View Postmy h96 max to this day the firmware x99 vorke z3 yundoo y8 i installed Magicsee N6 Max is the best for me Magicsee N6 Max not only working with a mk39 u installed but it is not working
so you mean you already installed all this Roms , even the N6 Rom to your Box , and all are running
well , is this correct ??? , really not sure what you mean ,
Hi ,
Originally posted by guner67 View Postno, my h96 max only works Magicsee N6 Max firmware nice c port usb3 port we are not working only on the led I'm not playing the game only film streaming kodi
so the N6 Rom runs well , but no Ports are working , correct , you not
need them , if it is no problem for you then it is okay , think your Box is
DDR3 too , maybe DDR4 is backwards compatible , but i think it is not
the same reverse , that why User "madji" bricked his Box ,
good luck / gefattern
Hi ,
yaa but due wifi not working i flashed with EBox R99 7.1.2 firmware by Rockchip Create Upgrade Disk Tool v1.53
after flashing X99 not working anymore I tried many firmware by using :
1-Rockchip Create Upgrade Disk Tool v1.53
2- AndroidTool_Release
3-RockChip_Batch_Tool
thanks for help.
Hi
thanks for help.
what do you mean with not working , no boot , or only no Wifi ??? , please try to
restore in MaskRomMode with Stockrom , you can find here , also use the latest
Drivers & Flashtools for it , good luck / gefattern
Hi ,
Can you explain please ?? how to do it for X99 ??
There are currently 2553 users online. 0 members and 2553 guests.
