X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    i tried both
    and what about LoderMode??
      Originally posted by majdi qurony View Post
      i tried both
      Hi ,
      if you can get your Device in LoaderMode , you only have to press restore / upgrade
      in Flashtool and wait till ready , LoaderMode is the stock Flashmode ,
      please report your results , good luck / gefattern
        [QUOTE=majdi qurony;n760438]i tried both
        and what about LoderMode?? ,
        please upload the Pictue again , maybe on a Picture Uploadsite ,
        and Link here ,
        thanks / gefattern
          Hi ,
          any results ,
          gefattern
            Hi ,
            any results ,
            gefattern
            Hi
            Sorry I have early shift today
            Tonight I?m going to try
            Any video or tutorial may it help??
              Hi
              Hi ,
              not really , but you can look on YT for it , good luck / gefattern
                Unfortunate,, I tried but nothing worked
                Thank you very much.
                  Hi ,
                  please upload the Picture again , i was not able to see it , not working ,
                  second , please try to connect your Box into "LoaderMode" to see if it
                  works ,
                  1. load FW to Tool
                  2. press the "reset" Button , small Hole , hold it ,
                  3. connect USB
                  4. connect Power
                  try it this Way ,
                  and please download the latest Drivers and Flash & SDTools from the
                  Link i gave , i always had same Problems with SD restore for my UT3 ,
                  but i found out that in this Tools (Link) one of them has special SDboot
                  Loaders inside the Folders , maybe this was always missing , first Time
                  that i saw this ,
                  HPH NT-V6 RK3288 Custom Nougat ROM v1.0 19-12-2018 Fixed ir remote Fixed OTG USB Port Fix resolution saved after reboot Fix Home button Add support for Amazon
                  please report if your Box was able to get in "LoaderMode" , hope you will
                  get it , good luck / gefattern
                  Hint : Pages before User "bergamesk" discribed how to use the SD Way
                      Hi ,
                      please use a copper wire for shorting , this looks for me little strange ,
                      and you really know which one is the "reset" Button ??? , think well , now
                      only can hope you will get it , did you load the SD Tools ??? ,
                        short the "three pinout" to enter maskrom mode
                          This is for X99 TV Box Firmware (20181024) Plugin the big USB plug into your computer the small 3.0 USB cable first into the box. Then hold the reset button and plug USB(big) to USB (big) into 2.0 USB on your computer and other end into the box (X99) while holding reset button. You will hear a sound knowing your box is connected. Then startup the RK android tool v2.43, load the firmware and hit upgrade. This is for 20181024 and its rooted and it works great when I hook it to my TV.
                            Remember you need 2 WIRES not 1. Don't need a power supply just the 2 USB wires.
                              Hi ,
                              so you mean , they changed the Port for flashing ??? strange , but if it really works we must inform "madji" ,
                              thanks for Info , good to know , greetings / gefattern
                                Hi beppin ,
                                so you say all 3 Points must shorted , really strange never seen or heard , but if it really
                                works we must inform User "madji" that he can restore his Box this Way , really good to
                                know , for Future ,
