General | Brand: Nexbox Model: A95X Pro |
Hardware | OS: Android TV CPU: Amlogic S905W, Quad core ARM Cortex-A53 GPU: Mali-450 penta-core, up to 750MHz+(DVFS) RAM: 2GB DDR3 ROM: 16GB eMMC |
Communication | WIFI: Built in 2.4G WiFi, support IEEE 802.11 b/g/n Ethernet: 10M/100M |
Media | Video decorder: 4K, H.265, MPEG1/2/4, H.264, HD AVC/VC1, RM/RMVB, Xvid/DivX3/4/5/6, RealVideo8/9/10 Decoder format: 4K@30fps, H.265, AVI, H.264, VC-1, MPEG-2, MPEG4, DIVD/DIVX, Real8/9/10, RM, RMVB, PMP, FLV, MP4, M4V, VOB, WMV, 3GP, MKV Music format: MP1, MP2, MP3, WMA, OGG, AAC, M4A, FLAC, APE, AMR, RA, WAV Photo format: JPEG/BMP/GIF/PNG/TIFF |
Interface | 1*HDMI 2*USB2.0 1*AV 1*TF Card slot 1*RJ45 1*SPDIF 1*DC in |
Other Features | Language: Chinese, English ,Germany, Japanese, Korea etc. 24 languages OTA: Support OTA update Network Function: Miracast, Airplay, Skype chatting, Picasa, Youtube, Flicker, Facebook, Online movies, etc. |
Power | DC 5V/2A |
LED Indicator | Power ON: blue; Standby: Red |
Package Contents | 1 x TV Box 1 x Voice Remote 1 x Power Adapter(A right power adapter will be sent as your shipping country) 1 x HDMI Cable 1 x User Manual |
Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Specification
GeekbuyingLast edited by trebor; 12 April 2018, 20:18.Tags: None
Today we can have a look at the
Another in the series of 905w that has HD Netflix (720)
Neat looking unit, BT Dongle Remote
Let's have a closer look.
The Box
Contents of the Box
Ports
Remove the Base
Couple of screws out with PCB
and the bits that make it happen
Geekbuying
H20 White Backlight Full Screen Touchpad Mini 2.4G Wireless Keyboard Air Mouse for TV Box/Pad/Laptop/PC - Black
Also while Testing the a95x I also be having a fiddle with The Newer H20 Keyboard/Mouse this one has buttons previous model was all touch.
Good looking unit also, flip it over and has the Touch mouse pad,
Fully backlit, the touch pad will stay illuminated for about 5 seconds flashing..
Multifunctional wireless keyboard combines with keyboard, mouse and touchpad.
Tiny size and lightweight design can make you use the keyboard easier without wire limited.
Plug and play, no need to install software any more.
Feature with an auto sleep and wake mode, the user can wake the unit up by pressing any key.
System Requirements:
HID compatible USB HOST device
Window XP Vista, 7/8/10 Linux Android OS with standard USB interface.
Powered by the built-in lithium ion battery, rechargeable function and long time using.
Perfect tool for PC, Pad, Android, HTPC, IPTV, HD player and other devices.
Lets start to have a look at the
Very Good indeed, one could say I am nearly Impressed, with the startup and how this box is presented, it does as it should and does it well.
WiFi and set up with Google excellent via Phone Tablet worked as it should.
Update and installed apps all good.
Also installed Aptoide TV to get a few extras also easy.
Even an Ota update, great to see.
Voice remote works well,
No problems using the small H20 Keyboard as mentioned, only thing no print screen function found yet so back to the k400.
Has a root switch that will be handy, to switch On or Off as required
Lots more I guess as I find it
Ok a bit of a look around:
UI updating apps
App Draw with apps
System Information
Ota Update
Advanced Settings (Root switch) and More Settings as well
Display
Ram and Storage Truth
DRM Info L1
CPU-Z
Geekbench CPU More Info > http://browser.geekbench.com/v4/cpu/8227710
Geekbench Compute
A1 SD Bench
Originally posted by humanoidtypo View PostWhy does it only support Netflix at 720p? I thought it has Widevine L1. Doesn't that mean it will support Netflix 1080p?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Just received my box, and YES, it does indeed support Netflix in 1080P with DD+ surround sound.
Some users in this thread (http://freaktab.com/forum/tv-player-...-control/page2) are reporting issues with Netflix: "Netflix works in HD but there's a thick grey bar at the bottom and black bars on the sides. Thought it could be not scaling from 720p to 1080p so changed native resolution to 720 but still the same."
Are you having the same issues?
Also, I have an older AVR with only an optical input. Do you know if I can still get Netflix in 5.1 surround sound? I was thinking I could use the optical out port on the A95X Pro (directly connect the box to my AVR). How is your system set up?
Thanks for the help!
Amy idea if this will be fixed via an OTA update? The netflix issue is the only thing holding me back from purchasing this. Seems like a good deal for a box w Android TV OS.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I was trying to make a backup of the firmware for this box using Titanium Backup app, but now my box is DEAD. I was missing functions from Titanium, so it think it needed the files form SuperSU. After reading all the horror stories about installing SuperSU killing their Amlogic boxes running Nugget, I figured, what the heck, pulled the pin on the hand grenade and installed SuperSU. Now I am hung up in the Android boot screen.
Guess this box is done for until WE get an img firmware to re-install....... Looking for the reset button now, perhaps in the AV hole....
Edit: from looking at Trebor's pictures of the board, the reset switch is behind the AV hole. Now need to know which of the two USB ports is the OTG port.........
Edit 2: Util they post a firmware, I will run CoreELEC for testing purposes. CoreELEC installed easily, and the remote works, but not WiFi. It does run CoreELEC very well.Last edited by clarkss12; 18 May 2018, 16:32.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by NayamAmarshe
Never flash SuperSU without confirmation of working by other people. Magisk is the safest and the new way to install supersu. I hope you fix the box.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Well, I JUST confirmed that installing SuperSU WILL kill your device. So, everyone should be grateful for me doing that for them. Someone had to take the lead and try to install it onto this device.I also killed my GooBang Doo Abox A4 that is virtually a clone of this box by flashing SuperSU and the binaries. I am also stuck on the Android logo and waiting for a firmware release. Can someone help please?
Originally posted by NayamAmarsheFlash Tanix Tx3 Mini firmware or atvXperience
Sent from my F3116 using TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3926 users online. 0 members and 3926 guests.
