I saw in previous comments from people who made it recognized as mecool's box and netflix returned to HD. Any chance of doing that and working?
Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
MeCool post a burnkey apk file for M8s boxes that solve the problem with NEtflix white app.
For us with A95Xpro any news ?
Also i check wireless update option and find that there is a new firmware 7.5mb only but when i press install, box reboot and error status 7 appear on screen. Any doubt about this please ?Last edited by rebelos; 03 August 2018, 16:28.
I ordered this box based on the perception that it was good to go for Netflix. It arrived yesterday and it seems I'm going to be sadly disappointed.
Anyway, I found this thread and I WAS able to install the update but sadly Netflix is still a no-go. I'm not 100% but I think it was just a security patch update to December 2017.
Hı guys I was trying to flash brunomsg 's stock firmware. But now Im on m8s pro w firmware and when I try to flash it to my device Im getting error 7. Its about my props not same the zip file and twrp not allow to flash this rom to my device I need help I cannot fix that problem have a nice day
hello there, i update te a95x pro to the lastest stock firmware and ther is a problem with the google cast receiver apk, it´s stock at the 1.27 version and i can´t update it with google play (gets error) even manually.
does someone know how to fix it? because i can´t cast anything.
thanks!
Originally posted by emirefekHı guys I was trying to flash brunomsg 's stock firmware. But now Im on m8s pro w firmware and when I try to flash it to my device Im getting error 7. Its about my props not same the zip file and twrp not allow to flash this rom to my device I need help I cannot fix that problem have a nice day
I just got this box and I don't have much experience in this field.
Basically I want to see movies and tv shows, I downloaded Showbox and works on/off, not 100% happy with it. I tried to add Kodi but t seems the repositories don't work.
Is there any other APP you recommend to stream or download movies? I also have VLC to play them.
Terrarium TV + MX playerOriginally posted by BixarracoHi,
Hi guys
someone could help me with the original remote.conf file of the A95X Pro box. I put the firmware of the Mecool M8S PRO W to revive the HD netflix again. everything is excellent but on the remote control the shutdown button does not work and so I read when replacing it with the remote.conf stock of the A95X Pro should work again.
Now you have to pull the power cable to turn it off and connect it to turn it on.
Thank you
Thank you
There are currently 2114 users online. 3 members and 2111 guests.
