Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Originally posted by moussboss59 View Posthello, you can give me image (.img) firmware a95x pro , to flash it with USB_Burning_Tool and make a restoration thank youMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by carlosslpmx View PostHi. I just got this TV Box and everything works fine except YouTube. It suddenly freezes the TV box and I have to restart it. I tried uninstalling the app's updates and deleting data, but it doesn't work . I'd really appreciate your help.
Originally posted by Bixarraco View PostHi,
I just got this box and I don't have much experience in this field.
Basically I want to see movies and tv shows, I downloaded Showbox and works on/off, not 100% happy with it. I tried to add Kodi but t seems the repositories don't work.
Is there any other APP you recommend to stream or download movies? I also have VLC to play them.
Originally posted by rafaam View PostWell, the prime video app is not working, but i got to see amazon prime video with the tv box by miracast, and also with google chrome, playing through the browser, checking the '' show page as desktop'' box
Yeah, the f***in Netflix people made something again, now i get the ui-800-3 error message right after opening the app, i tried factory reset and install burnkeytool again, but, now i just get an error connection to the internet which isn't true because youtube and everything with Internet works ok, let's wait for another OTA update to fix it (i hope so! )
Originally posted by aliax95pro View Post
Theres a particular build of amazon prime video that works fine for me .Subtitle dont work. Only problem that i have noticed. The only build of amazon prime video that worked on my Leeco super x55 tv and works on a95xpro . Shall share the link to it (apk) evening.
Originally posted by moussboss59 View Posthello, i have a problem with netflix with my box a95x pro, after the last update netflix work but since it was error network-code ui-800-3, had you the same problem
There are currently 1921 users online. 1 members and 1920 guests.
