Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Originally posted by fresam View Post
Originally posted by tombraga
I don�t agree with mo123 comments that only Mibox will be the future. I already bought a lot of "cheap" TV Boxes and there are (in the most cases) always a solution. And it�s good for us to try always find a solution and not go the easy way and pay the rich ones....
I want a solution that works out of the box. I don't have time to tinker anymore.
I've tried the Xiaomi box already but didn't like it. WiFi only, only 1 USB port and some of my side loaded apps refused to work at all.
It looks like the shield is the way to go but it's overkill purely to get HD Netflix.
Sent from my TA-1021 using Tapatalk
Hi.
No solution to update a95x pro Android TV> ver. 09/19/2018 when there is an error status 7?
Thank you.Last edited by LeGrandMarc; 06 October 2018, 01:28.
Thank you.
Still trying to push the failing OTA after nearly 2 weeks.
No attempt to correct the new one or even pull the problematic one.
ABSOLUTE INCOMPETENCE FROM THE DEVELOPERS...
Re-edit
Here is the solution to bring back A95X Pro box to its original rom. Also fix the Netflix issue.
Those who have soft brick their box by flashing supersu or flashing other firmware that cause to lost their widevine DRM Level 1.
Download and prepare all the required files. Download link
Part-1 - Download all the files from Part-1 Folder to your Desktop Computer
Part-2 - Copy the downloaded files from Part-2 Folder to the root of your MicroSD Card/Flashdrive
(Replace XXXXXXXX to match your box serial number in the TWRP/BACKUPS/A95X2018XXXXXXXX folder
if "unknown", proceed to Task 1. You can retrieve the serial no. after flashing the M8S Pro W or ABOX A4 firmware)
Task 1 - Use Usb Burning Tool - Flash M8S Pro W (Non-ATV)firmware to your A95X Pro box. (File: M8S PRO W-NHG47L-20171030.152444.V0619.img)
Task 2 - Use rom Update Tool - Insert MicroSD Card/Flashdrive and update the M8S_PRO_W-ota-20180802.182556.V0213.zip file with the update tool.(Local update)
2a. Now you have M8S Pro W Android TV rom on A95X Pro box. Next Install Netflix. Connect to internet, launch Netflix to see if it works.
Skip (2b) if Netflix works.
2b. If Netflix prompt with error code then install the Burnkey Tool.apk and run the Burnkey app. Once "success" reboot box.
Task 3 - Use Usb Burning Tool - Now flash ABOX A4 firmware over the A95X PRO Box with previously install M8S Pro W Android TV rom. (File: ABOX_A4_20180507.img)
*When you are on ABOX A4 firmware, during setup, a remote pairing screen will pop up.
Select "Bluetooth permission request (com.android.settings)" and NOT "(com.android.tv.settings)" and "deny" the "Bluetooth ON" request.
Task 4 - Use TWRP Recovery - Restore A95X Pro backup files. To boot to Recovery, first install "Terminal Emulator.apk"
HOW TO USE THE USB BURNING TOOL?
Step 1 - Unplug the box from power.
Step 2 - Open usb burning tool software.
Step 3 - Go to File > Import image > "Locate the firmware .img file" . Wait for the image file to load.
On Configuration settings, checked(√) on "Erase flash"(Normal erase) and "Erase bootloader"
Step 4 - Connect usb cable(male to male) to Computer usb port. Don't connect the other end usb to the box yet.
Step 5 - Click "Start", using pin or toothpick, gently press down and hold the recovery button (AV port) on A95X Pro box.
(FIRST, TRY TO CONNECT USB CABLE DIRECT TO BOX WITHOUT USING THE RECOVERY BUTTON. IF CANNOT THEN PROCEED FROM "STEP 5")
Step 6 - While holding the button down, now connect the other end usb cable to the box usb port(the one nearest to DC port).
Step 7 - Keep holding the button until you see the device connected. When this happens release the button.
Step 8 - Once flashing completed, pull the usb connection from the box then click "Stop". Close the program.
HOW TO BOOT TO TWRP RECOVERY? (You need to connect a usb mouse for TWRP backup restore)
Step 1 - Go to Apps Drawer(Sideload Launcher). Launch Terminal Emulator app. Type " reboot update " (without quote).
Step 2 - On boot recovery, "Apply update from EXT" > "select your source" > "TWRP311.zip"
NOTE: Checked(√) "BOOT", "DATA", "LOGO", "SYSTEM", and "RECOVERY" to restore.
Step 3 - Finished restore. Reboot system.
Step 4 - Now you have a A95X Pro box with its own rom and a working Netflix. Finally do a Factory Reset on the A95X Pro box.Last edited by neodela; 16 October 2018, 19:50.
Originally posted by neodela View PostThis is the solution to "Temporary lost of widevine level 1" and fix Netflix issue. Forget about the last OTA update(25.18mb). That update install a black version of Netflix and installing white Netflix will not work. They patch update modified the system file.
Make a full TWRP backup of A95X PRO box not later than A95X_PRO-7.1.2-201808101836 Build. (Does not matter if you have "TEMPORARY" lose the widevine level 1)
USB Burning Tool - Flash MS8 Pro W Firmware to your A95X PRO box. (Check drm info make sure widevine level 1 exist after flashing)
Download - M8S PRO W-NHG47L-20171030.152444.V0619.img (Non-ATV OS)
Download - M8S_PRO_W-ota-20180802.182556.V0213.zip (update to ATV OS. Use the in build OTA update tool to update.)
Download - BurnKey tool.apk (Install. Run the BurnKey tool app. Once success reboot the box. (Launch Netflix to see if it works)
USB Burning Tool - Flash ABOX A4 Box Firmware over the A95X PRO Box with previously install MS8 Pro W firmware on it.
Download - ABOX_A4_20180507.rar
Choose "Bluetooth permission request (com.android.settings)" and NOT "(com.android.tv.settings)" and deny the "Bluetooth ON".
Boot to TWRP recovery, now restore the A95X PRO TWRP Backup that you did in the beginning.
NOTE: ONLY CHECK "BOOT", "DATA", "LOGO", "SYSTEM", and "RECOVERY" to restore. Uncheck the rest.
Finish restore.Reboot. Now you have a A95X PRO Box with widevine level 1 and working Netflix.
Do a factory reset and proceed with all available OTA update EXCEPT the last update (the 25.18MB update size).
Netflix is OK now Youtube too ,wifi OK YOU ARE GOD
I dont make a backup so i cant go back to A95X pro firmware.
Everything working fine in ABOX A4 firmware except voice and power button.
If you know a way to make them work ,or if you have a TWRP backupo to upload so i can flash again you will save me from to install again a A95X fw and make all that things again from start
Originally posted by Dizzy74 View Post
WOW amazing i try it an everything works fine.
The power button did work for me but no chance to check on the voice button on ABOX A4 firmware.
Please check the post again for A95X PRO TWRP backup download link. I have updated a link.
I try to find a way to make the power button work when i am in ABOX A4 frimware (maybe need a factory reset,if you say works for you) if the mic in the control dont work i dont care so much,i am afraid to go back to A95X pro fw because the mouse movement is so stable and smouth in ABOX A4 fw.
In A95X pro fw the mouse button is laggy and missing steps in movement, very dificult to point in certains rows when you browsing and when try close tabs
Originally posted by mrpunch View PostDo you have a link for the correct version of TWRP?
You're running it from the SD card, right?
TWRP311.zip
Just place the zip file on your external storage. Don't extract.
Boot to recovery, "Apply update from EXT" > select your source > select TWRP311.zip
Hmmmm
The links in your original post are incorrectly formatted and can't be downloaded....
I'm just a little bit suspicious now.
I download Netflix that dont work ,i use Burn Key tool and everything its ok Netflix working fine and is the same version i use in my Sasmung S9.
Abox A4 fw is amazing ,i make a try to restore the twrp to A95X and if i am not happy i go back to ABOX A4 fw.
Stay suspicious we want to brick your device you have right,lmao
You are not suspicious you are idontthaveideawhatisay because i cant use the word start from I and ends to diot
Thank you very much
If you feel ABOX A4 firmware suits you, you might want to remove or disable one of the bluetooth apps.(i can't remember the app name) that make the remote pairing screen pop up at times.
i amin TWRP now looking to find a mouse to proceed to restore the TWRP backup you upload
Thank you very much again.
You must make a Youtube video solution many people looking for that
Hmmmm
http://freaktab.com/forum/tv-player-...dtv-experience
Credit to him. If you say the link don't work then you might want to tell him. I have no problem downloading the file.
Hmmmm
can you please discribe what the Problem is ??? , do you mean the Link of User "neodela" in Post
#235 or# 239 , both work , #235 is Ziggyshare , #239 is a Freaktabpage to N.A.s CustomRom ,
greetings / gefattern
There are currently 3415 users online. 0 members and 3415 guests.
