Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Hello, I have the same connection problems with the Netflix application, have a temporary solution installing version of the app 4.3 . Here the download link https://mega.nz/#!YR8xASQJ!crUcb-pw5...BzkJak1lTZrLjM
Originally posted by moussboss59 View Posthello, a new update ota has arrived you can put me in zip to be able to reload it because when I made the update from the box his writing mistake, I do not know if it's because of the fact that I removed the root
I'm not sure.....Are the source and target reversed?
Originally posted by mrpunch View PostThe update is also failing on my box which is running stock firmware...
This happened before the last update and they released a working one a couple of days later.
Sent from my SM-P555 using TapatalkYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I have a theory (on my problem at least) after finding this info on another forum:
A non-rooted Android device only displays a Status 7 error when a system update is being flashed onto it and something is found to be out of place or, to be more precise, modified.
The Status 7 error only affects non-rooted devices that are not in complete stock condition, so the only way to fix the Status 7 error on a non-rooted Android device is to restore every bit of the device back to its stock condition.
Originally posted by mrpunch View PostThe failed update hasn't bricked my box. It restarts normally after a power cycle but remains on the original firmware.
Originally posted by Knuistenbek View Post
Same error here, seems like we all having this problem trying to install the new OTA update, very strange...
EDIT: i managed to upload the UPDATE.ZIP file here... https://we.tl/t-SqM3QI3Zl5 if somone else wants to try, but, it doesn't work, i've tried copying into the internal memory and into an external HDD and same problem always, even after a factory reset, but, nothing!!!Last edited by krde; 20 September 2018, 19:07.
There are currently 1417 users online. 0 members and 1417 guests.
