Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Originally posted by jesusmaHi, Tello if im wrong. Just select instalo update, select twrp311.zip. then i boot on
twrp. Just use restore and select The file You send me. Ok?
Originally posted by brunomsgNayamAmarshe did you received your box?
Originally posted by jesusma View PostHi hdcardoso483. I try to boot, but stick on the media center red image. I have a nexbox a95x pro s905w 2gb ram 16gb rom. Maybe delete caches?
If you are on the nexbox a95x pro leanback room from stock you are not supposed to that you only do that if you are in some other device, that is the only issue that I found, the system is hanging trying to load something from data itsi fixable let me know
Originally posted by NayamAmarshe View Post
Bruno TWRP?
Originally posted by hcardoso483
He means this guy Brunomsg gave him a system backup, the odd thing they are all from that guy that I told to flash unsu.zip, he provided a backup without date now maybe that's what he was missing using know for it to run on the x96mini I had to make a lot of changes coz I don have the data partition and some libraries are stored there that's why I could not help clarcjoson with a backup he already had flash another firmware, (I think that's his username can't remenber) to recover he's stock, so this guy Bruno gave him also a backup but without data partition is the same they will miss some stuff unless the have datapartition and all the other hidden files intact but still needs modding...
There are currently 3853 users online. 0 members and 3853 guests.
