Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Here is the build prop from my Nexbox A95X Pro. But it is NOT the original firmware that was installed from the factory. BUT, it is now supposedly, back to the stock, minus the Widevine Level 1, which is now in heaven.......
build.prop.txt
Edit. Of course I had to add the .txt to the end of the file. This website will not allow a .prop file to be upladed, I assume for security purposes.Attached FilesMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12Here is the build prop from my Nexbox A95X Pro. But it is NOT the original firmware that was installed from the factory. BUT, it is now supposedly, back to the stock, minus the Widevine Level 1, which is now in heaven.......
build.prop.txt
Originally posted by clarkss12 View PostHere is the build prop from my Nexbox A95X Pro. But it is NOT the original firmware that was installed from the factory. BUT, it is now supposedly, back to the stock, minus the Widevine Level 1, which is now in heaven.......
build.prop.txt
I was not kidding.
This box is s905x box. Check the build.prop you sent me.
# begin fota properties
ro.fota.platform=AmlogicS905X_7.1
ro.fota.type=box
ro.fota.app=5
ro.fota.id=mac
ro.fota.oem=cyxtechS905X_7.1
ro.fota.device=A95X PRO
ro.fota.version=A95X_PRO-7.1.2-201806201412
# end fota properties
ro.expect.recovery_id=0x5d22d61ec176e06679b6bc17d8 c2475e7eae7ab5000000000000000000000000
It's an s905x box because s905w doesn't support widevine integration.
Originally posted by NayamAmarshe View Post
Did you see that?
I was not kidding.
ro.fota.type=box
ro.fota.app=5
ro.fota.id=mac
It's an s905x box because s905w doesn't support widevine integration.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Are you sure about that?? My "W" box does seem to be "slower" than my other "S" box. But, yes I saw that.
Originally posted by NayamAmarshe View PostI am pretty sure about it. This is because my friends at amlogic told me that s905x can be modified to work like s905w. That is how they did it. Use a downgraded version of s905x and then implement widevine to make it look like s905w.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi guys, I bought a nexbox a95x pro and it worked perfectly for a few days. However, now when I open netflix, it tells me "netflix encountered an error. We'll try again in ... seconds.
Code: NW-6-404.
One only thing I did was install an update via ota ... My device has a kernel:
3.14.29 eric @ ubuntu-server0003 # 5 Wed Jun 20 10> 20:35 CST 2018
Version number: A95X_PRO-7.1.2-201806201412
I have already returned the factory settings from the android menu, uninstalled and reinstalled the app and the error persists. Do you have any idea what that might be?
Originally posted by AnderDiniz View PostHi guys, I bought a nexbox a95x pro and it worked perfectly for a few days. However, now when I open netflix, it tells me "netflix encountered an error. We'll try again in ... seconds.
Code: NW-6-404.
I have already returned the factory settings from the android menu, uninstalled and reinstalled the app and the error persists. Do you have any idea what that might be?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1883 users online. 0 members and 1883 guests.
