Sent from my SM-P555 using Tapatalk
Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Originally posted by mrpunch View PostJust out of interest, which directory was it downloaded to?
To be honest, I'm not really bothered about this update or even a new one that installs and "fixes" Netflix.
The last one lasted about 3 weeks before Netflix blocked it again.
Unless the developers officially license Android TV, it's only a matter of time until it's blocked.
Sent from my TA-1021 using Tapatalk
Originally posted by clarkss12 View PostNext, i found the original Mecool M8S Pro W firmware from this site ( https://chinagadgetsreviews.com/down...-w-tv-box.html), it was an older version of the firmware and not the ATV version, but was in an IMG format so I could burn it to my box using the USB Burning tool. After I got it installed on my box, it now thinks my box is an official Mecool box. Next, I downloaded a newer OEM firmware from Magendanz's page, copied the file to a USB pen drive. Inserted the Pen drive into my box and using the UPDATE app from Android, I wiped data and media. After box rebooted, took awhile for the firmware to setup, but now I have an ATV Andoid, ALMOST the same as the original firmware..
Now, Voice works, and I have my Widevine DRM level 1 back, so now I have Netflix in 1080p with DD+
Then the Magendanz oem firmware, which one you used exactly, can you tell me the link of the rom and the name of the file,thanks a lot
perhaps is it this one from here? http://freaktab.com/forum/tv-player-...android-tv-7-1
Originally posted by tombraga View Post
I also bricked my box and i want to make the same steps as you, first i will try to install with usb burning tool the m82 pro w firmware.
perhaps is it this one from here? http://freaktab.com/forum/tv-player-...android-tv-7-1MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by tombraga View Posthow can i connecto to my usb burning tool? there is no hole to put it into recovery?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Did you find the reset button?? It is located in the AV hole.......
I already flashed with usb burning tool the mecool firmware. You are really great, you helped me a lot.
Now i would install Magendanz ota rom, perhaps you can check, if this is really the same rom i found as you have?? thanks a lot for your great help
i tried this rom, but it did not work, aborted message error: this update package is intended only for the M8S Pro+
so would be great if you could tell me which rom exactly from Magendanz you used...thanks
Here you can download the latest official firmware from mecool m8s pro w android tv in img format to burn with usb burning tool: https://dc7.androidfilehost.com/dl/tYMRw7txYU2Ywdsad-P6ZQ/1538304552/1322778262903992671/m8s-pro-w-1g-29082018.img.7z
Originally posted by moussboss59 View PostHere you can download the latest official firmware from mecool m8s pro w android tv in img format to burn with usb burning tool: https://dc7.androidfilehost.com/dl/tYMRw7txYU2Ywdsad-P6ZQ/1538304552/1322778262903992671/m8s-pro-w-1g-29082018.img.7z
then you do the update ota: http://legion.name/upload/Smart-TV-B...2556.V0213.zip, you put it in a usb key and you make the update via the deco in parameter update ota
install with the one via USB burning tool : https://nl3.androidfilehost.com/dl/Y...2g-3107.img.7z
There are currently 3510 users online. 0 members and 3510 guests.
