Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
neodela can u explain this part in task2 "Task 2 - Use rom Update Tool - Insert MicroSD Card/Flashdrive and update the M8S_PRO_W-ota-20180802.182556.V0213.zip file with the update tool.(Local update)" is this update by pressing & hold recovery button & then apply update from sd card ? (OTA update ?) or there is a menu inside a box or option while box is on & running?
yesterday night i planned to start this procedure , i flashed first file with uasb burning tool , then used ota update to update , then i got now mecool ota firmware running ok with serial number showing & netflix is ok after using burn key tool , i noticed that mecool firmware much more better than abox a95x pro , , the only thing now i am trying to find a fix is power key shut down & a very crazy app called amazon prime video that can never work with me yet , thanx to every one here for help
Originally posted by jesusma View Post
Hi, Widevine is L1 but hdcp is unprotected. Must be 1.x think.
Serial unknow . How can I set manual serial ? Maybe editing build.prop
"Task 1 - Use Usb Burning Tool - Flash M8S Pro W (Non-ATV)firmware to your A95X Pro box."
Then launch DRM Info app. Show me the screenshot of your DRM information.
neodela do have any info regarding flashing box with atv experience , currently my a95x pro has latest mecool OTA firmware dated 02082018 , can i just flash this one over the current software? will it brick my box , the one here https://www.atvxperience.com/downloa...-october-2018/ ,
how i can run prime amazon video APK on mecool m8s pro w OTA firmware , i currently still have it installed on box , i tried but always gives an error mesaage " sorry this video cant play , please contact cutomer service" !!!!! this app acting so crap , i can watch on other smart tv the prime video but on my box with any firmware installed it will not work , is it because box not supporting microsoft playback drm ? as i read it somewhare
Originally posted by fresam View Posthow i can run prime amazon video APK on mecool m8s pro w OTA firmware , i currently still have it installed on box , i tried but always gives an error mesaage " sorry this video cant play , please contact cutomer service" !!!!! this app acting so crap , i can watch on other smart tv the prime video but on my box with any firmware installed it will not work , is it because box not supporting microsoft playback drm ? as i read it somewhare
You also can't use the phone app as Amazon blocks it on AndroidTV and Mecool/Nexbox firmware doesn't have a workaround as on some Rockchip AndroidTV devices.
Originally posted by aliax95pro View Post
here is the apk. on zippyshare. amazon prime that works on a95xpro.
There are currently 2075 users online. 1 members and 2074 guests.
