Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Thanks I have WidevineL1 but I cannot open Netflix its says error(-100) and I don't know what I need to do? Same error on M8Sw firmware and ABOX firmware too. After restore I cannot use netflix too. Btw I used burnkey on m8s firmware. Can somebody help??Last edited by emirefek; 10 August 2019, 13:40.
Hi Guys, I have this box as well, and did have trouble updating the firmware to the latest, even when doing it manually through recovery, it was giving the same error as everyone else is getting. The error persisted even after doing a factory reset of the box. I finally was able to update the box using the amlogic sd card maker program. This is the sd card boot maker not the burn card maker. These are two different programs. I basically used the u-boot.bin included in the program to format and make the card and then put in the firmware zip file: A95X_PRO-7.1.2-201808101836.zip, on the card, plus, these other files which I had previously extracted from the zip file: dtb.img, and recovery.img, and a copy of the u-boot.bin file. You put the sd card in the card slot, press the recovery button inside the av hole using a paperclip, etc., it takes you into recovery, choose the option to update from ext, and choose the firmware zip file. It updates fine without any errors, and you have the latest firmware, VIOLA!!
TX3 Mini firmwares works on A95X Pro.., so I tried ATV 9 based on UGOS for Tx3_mini.
Installation via computer, using the Amlogic Usb Burning Tool...
Everything is working...
Found on 4PDA.ru
You can also flash other firmwares for Tanix TX3 Mini....
There are currently 3674 users online. 0 members and 3674 guests.
