Nexbox A95X Pro Android TV OS 2GB/16GB Netflix 720P YT4K S905W 4K Voice Remote 2.4G WiFi LAN
Originally posted by wander_jarra View Post
But did Netflix work?
only turning off and on the tv box is the only problem, but I read in a forum that with a little work I can create a custom remote.conf file
Guest
Originally posted by mrpunch View PostIf someone tells me where to look for it, I'll see if it's still on my box.
Sent from my SM-P555 using Tapatalk
Thank you
Originally posted by Dr4v3n View Post
I'm having the same issue. Could someone, please, save and upload the update.zip?
Thank you
Originally posted by mrpunch View PostI found the ffota folder in the /android/data path but it was empty, even after enabling show hidden files etc. Sorry.
If it's any good to anyone, I'ver extracted the burnkey apk . The link is here if anyone wants to try it (at your own risk).
https://www109.zippyshare.com/v/J3F3DmsB/file.html
Thank you for trying. I suppose that the update.zip file is deleted after a successfully update. So the only away it will be download the update and copy the file before install it.
There are currently 2353 users online. 0 members and 2353 guests.
