If you want to do a backup of your rom (if it is the original rom), you can do that if you follow a simple tutorial. Use the software attached.
After you have backed up your rom, and you have extracted all necessary files from NAND memory chip, please upload to my personal cloud storage to compile them into single file and then you can use it with Factory Tool 1.6. with this link http://s.go.ro/ovn08jsx
I did the same thing with file sended to me from mike808.
Just be realy focused when you back up your rom. Read the tutorial with more attention. Good luck
