Netflix v3 is still working on your box? On my box, old version say it can not reach netfix... Or something about network connectivity, and latest version keep spinning the red circle and nothing happen.
X88 Mini Android TV 7.1 OS 2/16GB RK3328, Voice Remote YT4K Netflix 720P WiFi LAN USB3.0 VP9 H.265 DLNA Airplay
costinilie, I flashed the firmware, it was a success but when I plugged it back into the TV, I got the same problem, just with a different logo this time, is there anything else I can do, or is there a problem with my device?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by helpme123 View Postcostinilie, I flashed the firmware, it was a success but when I plugged it back into the TV, I got the same problem, just with a different logo this time, is there anything else I can do, or is there a problem with my device?
Latest updates....
Based on system.img modified by manu_manu4 (many thenks for your work), now we have a new version of stock firmware. Is in X88 Mini Stock Firmware and is named X88_Mini_Stock_Firmware_flash_NOAPPS.img
Basicaly is the same firmware without preinstalled apps and youtube. Now you are free to install whatever you want. If you need root, then follow instruction provided in How to ROOT folder.
chromcast is not working because is not a certified devices by google like Mi Box or Nvidia Shield. It is stable. Major issue was Youtube. Factory version was crashing and because was a system app, it was not possible to be downgraded.Now you can install whatever version you want. I recomand Aptoide market
nice... about chromecast certified... i dont think that is the case... there are a few android tv boxes that are not certified also get chromecast support... ya i use aptoide too... for me youtube and netflix doesnt matter... because my smart tv already has those apps... for me Kodi is most important... so if Kodi, browsing, Popcorn time, IPTV all work fine then ill be satisfied... cos this current firmware always hang which is super annoying...
Originally posted by manu_manu4 View PostCheck your DRM with DRM info apk
Originally posted by costinilie View Post
I checked DRM and it's L1. There is nothing changed about this. So you say that Netflix v.3 goes to you ??? And on the stock firmware, not on the alternate firmware. Please post here that apk version to test it too, I really do not understand why it does not go to me
I dont know why, but for me is not working. Maybe is something diffrent on your Netflix servers. Romania grant acces to Netflix 2 years ago. Maybe in my region is more restrictive then others regions. I dont know...But fot now, with stock firmare, no version of Netflix for Android TV is not working anymore. Sad....for me, this was the main reason to buy this box. Probably was the last bad choise. Next time i will buy only certificated devices. A little more mony to spent, but is worth.
You speak about to use an old version of netflix
Do you use Wifi or ethernet connection ?
Just you and me use Netflix on this box ?
it worked before changing the firmware, but from the date I changed it and until the date I put it back, something changed. Meanwhile, I used the alternate firmware. The connection is on cable, high speed, there is no problem from this point of view. With the latest version of Netflix 5.4.1 it made an error. Version 3.2.2 was perfect. Just after restarting, version 3.2.2 is upgraded to 5.3.1 which was pre-installed by the factory. I hoped that after I change the firmware and delete the preinstalled version, I can stay with version 3.2.2 without having any problems with autoupgrade. But meanwhile, Netflix has done something and now no version is working anymore.
Do you use the original firmware with which you bought the box or have you changed it in the meantime? I think there may be a problem with my firmware. It is based on system.img received from mike808. That's why I ask, are you using the firmware you bought the box or the one from me?
There are currently 1692 users online. 1 members and 1691 guests.
