X88 Mini Android TV 7.1 OS 2/16GB RK3328, Voice Remote YT4K Netflix 720P WiFi LAN USB3.0 VP9 H.265 DLNA Airplay
Finding the Bluetooth remote a bit ordinary, logitech k400 doing good.
Running and full 1080p View, Temps warmish 60~70c and could be better
Ram speed looking ok and unit does appear snappy.
Setup of Google account etc all good WiFi AND Ethernet not to bad
If they sort out the Paid streaming apps could be a winner
Can someone please upload a backup of the stock rom for this device? I had made a backup myself but for some reason it doesn't work, I forgot to backup the backup partition, maybe that's the issue.
Also, why is Gearbest.com is advertising this box as having 5Ghz wifi? Or dual wifi. Which is not the case, also, they have replied in the question and answers area on this product's page that it has bluetooth as well, which also not the case. There are specific question asked if this thing has dual wifi and bluetooth and they have answered falsely that it indeed does, which it not true.
If you made a backup to system.img is most important. I hope you made it with android tool. Please post here all partition. I will try to make it work using parts of diffrent firmware. All that i need is system.img and kernel.img Anyway....any start is a good start!
I'll upload all the backup images I've made including the system.img. When I restore these I just get a red light and the box doesn't boot, however, when I flash the image you provided it works fine, however, it's not Android Tv OS.
latest updates ... mike808....you are the man of the day !!!
Thanks to you now we have a stock firmware for the X88 mini
I will continue to delete the two applications Youtube and Netflix from the system, so we can install other versions that go smoothly. I will tell you what progress I have made. Once again I thank you for having patiently backed up the stock firmware. The problem was in parameter.txt. It was incompletely saved.
That's great news costinilie, can you please tell us what changes did you make to the parameter.txt to make it work? I want to flash the original rom as well to the box. Also, which tool did you use to flash the rom?
ENJOY!!! and once again many thanks to mike808 for system.img
Meanwhile, Netflix has modified something and now no version of android tv os is working anymore.
The tutorial i know about how to do NAND Backup is done by FinlessBOB. It starts with downloading parameter.txt
Just that tutorial tells you that you need to enter the value 0 and 2. Here is a mistake. Value 2 is too small and consequently parameter.txt will be read incompletely. I recommend a higher value. In any case ... it is a wonderful and very well-explained reading. For those who want to learn how to do NAND Backup.
someone with the stock firmware can check if Netflix for Android TV is still working. In my old versions, she says she can not connect, and with new versions she gets stuck in the red circle that is spinning. Is there a problem with you, or just me?
I've been working for nothing all night. My goal was to have Netflix HD and that could only be done with the stock firmware and an old version of Netflix. But they seem to have done their best not to use any more than certified devices. In this case, I do not think we have anything else to do. Only if those who made this firmware find a solution. Now there is no difference between classic Android and Android TV OS. Sin was a beautiful dream. Money you gave in vain, in a box that promised many, but that did not go as it should from when I bought it. I am deeply disappointed with the attitude of Netflix.
