All Android 8 roms can hide root via magisk!
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Hello I have this device and I came up a couple of problems. First the LED remains permanently red and second the control of the device does not work. I also have a problem with the original images that I download all supposedly are downloaded with an error in the iso image. Thanks in advance.
Originally posted by Jjgonzalez87 View PostHello I have this device and I came up a couple of problems. First the LED remains permanently red and second the control of the device does not work. I also have a problem with the original images that I download all supposedly are downloaded with an error in the iso image. Thanks in advance.
Originally posted by ath156 View Post
No if you have a recent release. Yes if you have an old one.
In any case if it is a ".rar" file, try also the latest winrar !!
Flash rom official and nothing the Led remains fixed red and the tvbox controller stopped working overnight also another controller that had USB stopped working. Use a different one than these and I can move around the menus but do not turn on the tvbox, I can think of power problems or hdmi cec. Has anyone suffered it?.
Hello again around here ... I would like to see if my h96 max x2 box could be saved, it is in a state that the PC does not recognize, I have used the GT King rom and I wanted to return to the original rom, I made a mistake with Amlogic burning tool , and check delete bootloader, the loading of the rom failed and the PC could never recognize it again nor could I do anything with the box, it does not pass the red light, I would like to have advice if there is any way to recover or it is not worth it, my version is 4/32, GB as always welcome any help !!
best regards.
There are currently 2950 users online. 0 members and 2950 guests.
