H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by MyVision View PostAm I the only one that's seemed to notice, that long pressing the remote OK button doesn't work anymore On the H96 Max X2. it use to work fine on the older devices, now it doesn't work at all, even with a downgrade to 8.1
Originally posted by pcdude28259 View Post
i never figured out how to get long press working on the custom rom ported over from the gt king, but using the stock firmware from here the long press function works fine https://www.h96tvbox.com/content/6-Firmware-upgrade
You can assign 3 different actions to each button (for Single press, Double press and Long Press).
Of course you cannot "fix" the Power button (to turn ON your box when it is shut down).
i never figured out how to get long press working on the custom rom ported over from the gt king, but using the stock firmware from here the long press function works fine https://www.h96tvbox.com/content/6-Firmware-upgradeLong press doesn't work on Apex or Nova launchers
Good evening everyone, my question is if there is any way to use this amlogic box as a Wi-Fi access point, I can't find the mode ... my model is Android 9 and the box is 4GB RAM and 32GB ROM, I also ask how it is You can access the full standard configuration of android, I really appreciate any help.
Originally posted by diegofreak View PostGood evening everyone, my question is if there is any way to use this amlogic box as a Wi-Fi access point, I can't find the mode ... my model is Android 9 and the box is 4GB RAM and 32GB ROM, I also ask how it is You can access the full standard configuration of android, I really appreciate any help.
In any case you must first connect to the WiFi and then you can reach the options for "access point".
Originally posted by ath156 View Post
I use the GT King custom rom and I have 2 icons for settings ("settings" and "droid settings'). If I open the "settings" there is another option inside "droid settings" and then "more settings" and then the settings you are looking for (which I can get from the 1st icon at once).
I am very thankfull for your help. I ask you to tell me which would be the correct custom rom GT king for my box, it is 4GB ram 32 GB rom comes with android 9. thanks again!!
My box is 4/64 DDR4 and was delivered with android 9. If yours is also DDR4 then you will have no problem using this rom.
I have uploaded the custom GT King rom that I use (look at my post #804).
Thanks again unfortunately I have tried many times to load the image of the rom I downloaded with usb burning tools, the latest version ... the penultimate ... and I always receive the message "key file configurated wrong!" I guess it will be some key to the image of the rom ?? I don't know, if you can lend me a hand here you would get me out of a predicament since I don't know what to do.
You can use the USB burning tool that is uploaded to the official site of H96 Max X2 (and don't forget to copy the LICENCE directory - watch the relevant video).
Have you copied the licence file to USB burning tool???
I just did it from another site the download link on the official h96 site is down, everything is working properly, I correctly load the rom ... this list to install, if I can check again, I would like to know what boxes check / uncheck before of loading the rom, excuse my ignorance greetings!
download the video file so as to know what to do exactly (maybe its better to download also the original Rom just in case you would like to go back to the original).
There are currently 2410 users online. 2 members and 2408 guests.
