Has anyone tried the new October firmware ?
H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by himtan View Post
Is there any possibility to brick the device by flashing the wrong firmware update ? Is there a way to find out if my version is 8DDR3 or LPDDR3 ?
Then try to ... flash the other!
As simple as that!
Originally posted by gatos814 View Post
If the firmware is not for your tv box the usb tool will stop with an error!
As simple as that!
After many failed attempts i managed to flash successfully the u214 firmware. Photo of the updated system :
And the lpddr3 pie version of this tv box has many changes and a first look of a Navigation Bar but unfortunately still without a status/notification bar!
So , as you figured out you have the good version of the H96 MAX X2 , the one which can take both of the 2 firmwares , its and the one for lpddr3!
How do you know that it can take both firmwares ? I think that it failed with the aml firmware, only u214 succeeded. At first it failed with both and i thought that it will be bricked for ever. Then i changed the software to latest "Amlogic USB Burning Tool v2.1.7.3" and tried both with key overwrite and without key ovewrite and i managed to flash it successfully.
that means that you have the version i told you!
And i know it because i've tested it myself very recently ... yesterday in a 4/64 from bg !
Originally posted by romcrazy View Postthen i found a comment on xda about the reset thing and it worked.
If you have used this firmware : https://drive.google.com/drive/folde...J-XHAImx91RH7z
Originally posted by salehdeh76 View Post
Can you please post the link to that XDA comment or explain more about the solution? I am very frustrated and keep trying burning a ROM into my s905X2 device but always get an error in burning tool, despite following all instructions!
Yes this is the firmware that i flashed successfully. If you can flash both of the firmwares how could you know which is the right (better one) for your device ?
It would work only with this one :
Hi, I've just bought an H96 Max X2 and it came with Android 9.0 loaded. It is sat next to the router so is cabled to it by Ethernet. All seems good but when I install NordVPN and connect to any server, the connection drops after approx 10 seconds and it disconnects the Ethernet connection. So I have to reboot the box to get it back online.
I spent an hour online chat with Nord yesterday trying different settings and the only way we could get it to work was if I used Wifi to the router instead of Ethernet.
Today I booted it into Recovery mode and did a Factory Reset, loaded Nord and tried it but it still has the same problem.
So I either have a faulty box or the firmware has a bug.
A friend has the same box running v8.1 and he runs Nord with no issues, so I'm thinking its the firmware.
Here is a screen shot of the firmware. When I ask it to update, the box says it is running the latest version with no further updates.
Are there any other v9 firmware versions I can try ?
thanks
Hello.I want to buy this box.but I have some general expectations:1)Does this box plays smooth 1920x1080p Netflix with Coreelec?(boot from microSD) 2)Can I find a twrp for this,then fully unroot and root with magisk?3) Does it have playstore?4)Is there any firmware with statusbar/navbar?If not,can someone suggest me another S905x2 box please?
Originally posted by Nqtraderman View PostHi, I've just bought an H96 Max X2 and it came with Android 9.0 loaded. It is sat next to the router so is cabled to it by Ethernet. All seems good but when I install NordVPN and connect to any server, the connection drops after approx 10 seconds and it disconnects the Ethernet connection. So I have to reboot the box to get it back online.
Give us more details because the 1st photo it's too small....!
Anyway .... if i see well on the second photo of yours you must have the lpddr4 (8DDR3) version so you can try and the other one from lpddr3 version which is this :
Good luck!
Originally posted by kos25k View PostHello.I want to buy this box.but I have some general expectations:1)Does this box plays smooth 1920x1080p Netflix with Coreelec?(boot from microSD) 2)Can I find a twrp for this,then fully unroot and root with magisk?3) Does it have playstore?4)Is there any firmware with statusbar/navbar?If not,can someone suggest me another S905x2 box please?
2) -- Yes , but no magisk so far on Android 9 in all these tv boxes...!
3) -- Yes
4) -- Android 9 for lpddr3 version has Navbar but hasn't status bar!
Better software support has beelink so far ...
There are currently 2082 users online. 0 members and 2082 guests.
