H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by gatos814 View Post
1) -- Yes
2) -- Yes , but no magisk so far on Android 9 in all these tv boxes...!
3) -- Yes
4) -- Android 9 for lpddr3 version has Navbar but hasn't status bar!
Better software support has beelink so far ...
I now have the choice of installing the .img file into either the Boot, Recovery or Logo partitions.
Which one do I choose ?
thanks
Originally posted by Nqtraderman View Post
Hi I haven't got the correct USB cable so I copied your .img file to a USB stick along with TWRP recovery.img and booted the box into TWRP recovery.
thanks
Please use only usb method!!!
If you don't have one of these cables , make 1 from 2 old phone cables , connecting them with the same color!
Good luck!
Originally posted by buttboyboris View PostMy box have started “flickering”, like in this video:
Is there a solution to this problem?
First try and other hdmi cables and ports on your tv
Then try with other firmwares to see if there is software or hardware problem!
Good luck!
i'm not sure if this is the right place to post this.. but i have a pendoo x10 plus s905x2 box. I burned the rom from here https://drive.google.com/drive/folde...J-XHAImx91RH7z and everything works great. only thing is the ethernet doesn't work but wifi is fine. now say i had a copy of the stock firmware for the pendoo x10 plus, how would one get the ethernet driver from the pendoo rom, and put it into the h96max x2 firmware? literally everything works great except of course these two devices have dif ethernet chips (pendoo gigabit, h96 is 100meg). clock display on the front of the box also doesn't work but i don't care about that
i'm assuming its gonna involve unpacking the rom and a buncha other complicated things that i have never done, but im willing to learn if someone can point me in the right direction. any help would be greatly appreciated.Last edited by pcdude28259; 01 November 2019, 04:07.
Originally posted by pcdude28259 View Posti'm not sure if this is the right place to post this.. but i have a pendoo x10 plus s905x2 box. I burned the rom from here https://drive.google.com/drive/folde...J-XHAImx91RH7z and everything works great. only thing is the ethernet doesn't work but wifi is fine. now say i had a copy of the stock firmware for the pendoo x10 plus, how would one get the ethernet driver from the pendoo rom, and put it into the h96max x2 firmware? literally everything works great except of course these two devices have dif ethernet chips (pendoo gigabit, h96 is 100meg). clock display on the front of the box also doesn't work but i don't care about that
I have my h96 max x2 lpddr3 4/32
Can I upload it too?
Originally posted by Georpap View Posthi guys! how can we reboot from android to coreelec? BTW coreelec fixed my problem with the resolution that i had with android os on h96 max x2..
Originally posted by kos25k View PostJust install reboot to libreelec app (needs root)Btw, how is this box?Especially on Netflix FHD on Coreelec?I can't choose between this and beelink gt1 mini..
I didn't try it with Netflix because my Samsung smart tv supports it and I don't have an active Netflix account this moment..with coreelec 4k streaming is flawless.. and the price is significantly low compared to GT1 mini.. I bought it for 37euros..but beeling has better support and better ui on androidÂ
There are currently 2139 users online. 3 members and 2136 guests.
