H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Hi.
I'm thinking about buying this box (but 4/64) and I'd like to know some things. Could you help me?
1, Is the box boot /start on after power blackout?
2, Is there WOL to wake on?
3, I read about wifi problems, is it frequent? I'd like to know it's worth to buy or it's a problematic box.
Thanks a lotLast edited by pszab; 09 September 2019, 06:47.
Thanks a lot
Originally posted by romcrazy View Post
If you depend completely on wifi, stay away. It has very bad wifi module. But if like me, you use ethernet, then this is as good a box as any. Even after power blackout when power comes back, it boots up itself. WOL to wake? No idea. I am assuming, with power button the box goes to sleep and comes back? Yes it does normally.
If anyone can help me with advice: I recived H96 MAX X2 4/64 with faulty lan port, its not working, i tried flashing and changing cable but lan is dead.
Meantime i ordered usb to lan cable, but now when cable arrived i can not make tv box recongnise it and use new usb to lan connection. Is there something i can do in root options or alike to make it work?
Please help with some advice...
Originally posted by Jole View PostIf anyone can help me with advice: I recived H96 MAX X2 4/64 with faulty lan port, its not working, i tried flashing and changing cable but lan is dead.
does anyone use gamepad to play game on this box?
I have 2 gamepads:
1. Ipega pg 9028 works well on this box and my old box ( m8s mini, android 5)
2. Ipega pg 9157 doesn't work at all on h96max x2 but works well on m8s mini.
I already tried android 8 rom and other roms but didn't help. I have no idea what else should I do , how to get it fixed.
Is it the box or gamepad fault?
Segej at 4pda ported the N5Max android 9 pie firmware a short while go and he recently added native upper and lower bars to that same firmware.
https://4pda.ru/forum/index.php?show...#entry87173464
Download the second one.
The only issue was that the two fullscreen apps that I used (a 3D game and smarthome launcher) kept auto-rotating to portrait mode. I had to go into the build.prop and change the rotation setting to force landscape mode.
The build.prop file I edited is located in root > vendor. And the two line I edited was:
persist.sys.app.rotation=force_land (I forget the original setting, probably should have wrote them down or did a backup but all seems fine).
After that simple fix, this firmware is probably the most 'complete' firmware I've used on this box. The navbar from the playstore was fine, but I just prefer native bars and the notification shade.Last edited by rahzel; 10 October 2019, 23:42.
Hello,
I have had this device for almost 6 months and it works good, but my girlfriend is having a hard time with the air mouse in the apps. Every app I download opens in “tablet mode” (Mobile), and I have to use my air mouse to navigate. Is there a way to “spoof” this device to start apps in a TV mode? Have read something about editing a file, but don’t know what device number I should use.
Is there a custom rom or setting to make this change?
EDIT: Found a ATV version by a user by the name “ sergej_a_g”, does this solve my problem? Where can I find the latest version and how do I flash?Last edited by buttboyboris; 08 October 2019, 23:05.
Hello all,
I try of upgrade my (H96 Max x2 Amlogic S905X2 android 8.1 4/32GB) to android 9 with cable pc usb/usb 2.0 port box
with usb burntool 2.1.6 and .img (i try many roms) with licences
with normal erase, whether overwrite key, mac, mac wifi checked
- aml_s905x2_H96Max_4g_mac_wifi_lpddr3_20190305.img
- N5MAX_4GB_20190702_to_H96 MAX X2_bar_by_sergej_a_g.img
- u214.H96Max_X2_4G_100M_9.0.2019.09.11.14.29.img
- aml_s905x2_H96MaxX2_4g_mac_wifi_20190114
My status is blocked at 3%: Download UBOOT with all ROMS, i try 1 day continue...
i try upgrade with recovery mode and micro sd but error 21?
what is the problem?
how know version of my box?
Models:
H92 MAX X2
Version noyau:
4.9.76 (gcc version 6.3.1 20170109 (linaro gcc 6.3-2017.02))
My build:
OPM1.171019.011.20181126 test-keys
Help me please, i'm in the cosmos ^^
Models:
H92 MAX X2
Version noyau:
My build:
Try with the usb burning tool 2.1.6.8 or the 2.17.0 !
There are currently 2014 users online. 1 members and 2013 guests.
