H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
    Originally posted by Serena
    Good for you ... but i think the wrong firmware must erase from this thread!
      Click to download H96 MAX firmware from VISSONTECH https://www.vissontech.com/h96-max-firmware/
      Not the same box, this one is H96 Max X2 with amlogic not rockchip.
        Hi everybody, new user here. Is there a way to enable navigation bar on a stock firmware?
          download nav bar from play store.
            Thankx, which one, this?
              Yes!
                My first post and wanted to say Hi and thanks to everyone for all the information in upgrading my box A question: Is there any way to modify the bootanimation audio file? When the splash screen first comes on, the audio is super loud. Thanks in advance.
                John
                  Originally posted by jcpriest View Post
                  My first post and wanted to say Hi and thanks to everyone for all the information in upgrading my box A question: Is there any way to modify the bootanimation audio file? When the slash screen first comes on, the audio is super loud. Thanks in advance.
                  John
                  That sound is annoying!
                  Maybe this? I would try it but I am leaving for a couple of weeks.
                  Is there any way for me to play certain audio files when my phone starts up and before it shuts down? I have a Samsung S3.
                    I have an app that works good on android 8.1 but on the new firmware android 9 It closes instantly
                    many solution?
                    another question, is there a good rom with status bar and Mac bar for h96 Max x2 ddr3 64gb???
                    thanks
                      many solution?
                      thanks
                      Which app doesn't work for you?
                        Partner tv app for tablets
                          Try OLA TV v5 for live channels all around the globe, and Beetv or Titanium TV to catch up on TV shows and movies. Both apps work great on my boxes. Check out Mobilism for download links.
                            Thanks but I need this specific app
                              on google play, it says that in won't work on pie. Also it gets a really low review score. Sorry
                                thanks
                                the low score is because the latest version won't work, so i use the older one.
