H96 MAX X2 Amlogic S905X2 Android 8.1 4/32GB Dual Band WiFi Fast LAN BT
Originally posted by Shawncck View Post
Originally posted by romcrazy View Post
Please first try different adapter. And try your current adapter on a different device. Maybe your adapter is faulty. You cant brick boxes by twrp restores. Unless you restored oreo over pie (that messed up the bootloader). And still the red light must come on. Does it not light up even on connecting to PC with USB wire? With reset button? Please try all options before trying the below method. I know it shows first two pins in below video, but it differs for different boxes. Please try all pairs of pins one by one. And give adequate time to each pair of pins. As in the video, you will do this process after opening usb burn tool and connecting the box with usb. With any luck, your pc will make a sound and the box will get detected in usb tool. If you have not managed to kill it completely.
https://www.youtube.com/watch?v=fsyS3p5asZs
The adapter is working fine. I open up the box and plug in USB but the led did not light up. And I couldn?t find which item to short it. Because the item in the video is different board. Any other way? Or if I post a pic of my board, u able to identify what to short?
i did a orea twrp restore over pie. Then no more light.
Post the picture. But dont get your hopes up. I have no idea how you have found unlimited ways to destroy your box. I have been flashing stuff for 7 years, I have broken 2 phones in frustration but always I found a way.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi here is the circuit pic.
Originally posted by bain19 View Postpicked up this "H96 MAX X2" off of amazon recently and I've only been able to find one firmware that has worked on the device
I found the firmware here "aml_s905x2_H96Max_4g_mac_wifi_lpddr3_20190305" ; Other link to firmware for reference here
Silkscreen on the actual board say:- s70-905x2-v3
- 2019-02-18
Images that havent worked:- X96Max_V311_4G_190302_to_H96MaxX2
- H96_Max_X2_s905x2_4g_20190114
- XTMOD_GT1MINI_1.0_PUBLIC_to_aml_s905x2_H96MaxX2_4g-Multi-port hellish mixture
- S905X2.HK1_PRO_AP6330_100M_8.1.2019.01.02.13.58
- aml_s905x2_X2_tubi_4g_mac_wifi_20181117
- u215.T10_PRO_4G_AP6330_100M_8.1.2019.02.20.17.02
At one point I bricked the device but I was able to short out the nand and flash it
Nand pins here
Pic's of board
Does anyone know what other images I can use ?
Looks like someone in this very thread has already done it. Take his help. He has given pictures for shorting also.
https://forum.freaktab.com/forum/tv-...680#post774680
I try to short that w a test pen, But still it does not light up. The power is working fine. What else could be the problem. Previously I plugged into PC and was able to detect in the burning tools. Now no response from burning tools. Any way to see if PC detect it?
Originally posted by gatos814 View Post
If it's not then something's happening with your tv box!
If it's something yellow then the drivers is not properly installed!
he has been flashing successfully earlier. He decided to restore oreo backup over pie. His bootloader has got cleaned so its not being detected. Only nand pin shorting method might work for him which apparently loads an internal failsafe bootloader but the guy who has performed this has not responded till now. basically what i understand is, you plug the box to pc while keeping usb tool on, and with a screw driver, short the pins shown in the picture. that means connect them temporarily with metal and the box gets detected in 5 seconds. but his box light is also not working and that is a very bad sign. in all short pin videos, box light is working already.
There are currently 2796 users online. 1 members and 2795 guests.
